- Posted on
Mon Aug 14, 2017 1:04 pm
matt (support)
offline
- Site Admin
If the log is showing "Received INSTEON ..." then the command is coming from that module (Garage Lights in this case), or there is a malfunctioning module that just happens to be spoofing that modules address (unlikely, but maybe the PowerLinc is malfunctioning?).
To turn on the debug Insteon logging: Hold down SHIFT and OPTION when you select Interfaces->INSTEON/X10 Power Line->Configure... and you'll get the debugging dialog. Check the LLIO debug logging checkbox and Close the dialog. I don't think that is going to give you any additional useful information though.
