PowerLinc Persistent Link
Mon Jul 24, 2017 2:53 pm
JohnS offline
I am running Indigo Pro, version 7.03 For the past week, once a day, I’ve been getting the error message below:
Received INSTEON 36.D0.73 on (button 4)
Group Trigger Error no address to name data found for received command:ackValue : 0
address : 36.D0.73
cmdBytes : [17, 0]
cmdFunc : on
cmdScene : 4
cmdSuccess : True
cmdValue : 0
replyBytes : []
Group Trigger Error Error in plugin execution ReceivedBroadcast:
File “plugin.py”, line 500, in insteonCommandReceived
UnboundLocalError: local variable 'cmdDev' referenced before assignment
The 36.D0.73 device does not show up in my Indigo device listing.
I have tried “Reset PowerLinc and Sync Links”. In doing so, I found that 36.D0.73 shows up as a persistent link in my PowerLinc as follows:
PowerLinc Linking - . . adding: INSTEON plc link to controller 36.D0.73, flags 03, group 01, data 00 00 FF
How can I get rid of this persistent link when I can’t find it any where else in Indigo.
Thanks for your time, John
Mon Jul 24, 2017 4:38 pm
Re: PowerLinc Persistent Link
That error is from the Group Trigger plugin so it's likely that it has an Insteon address cached in some way.
Wed Jul 26, 2017 12:48 pm
JohnS offline
Jay,
Thank you
Mon Jul 31, 2017 10:10 am
JohnS offline
Jay,
It turns out the issue wasn't the Group Trigger. Somehow I had a leak detector that had an address of 36.D0.73 but had a different address in the indigo database. Once I defined and synced the leak detector everything cleared up.
Thanks, John
Mon Jul 31, 2017 10:50 am
Odd - did you ever replace that leak sensor? If not, then I have no idea how it got changed - I'd be a bit suspicious of that device...
