Python x2 and using more CPU?
Fri Nov 25, 2016 3:18 pm
Different Computers offline
I started looking at this because my iTunes server on my Indigo machine suddenly started dropping signal/temporarily freezing. It's not just airplay--it stops locally too.
Looking at Activity Monitor, for the first time ever I see Python listed as a process--certainly not because it never ran before, but before I doubt it ever reached 1% utilization. Now I see one instance of Python taking anywhere from 0.5 to 70% of CPU time, and that latter often if not exclusively corresponds to iTunes hiccuping.
But there's also ANOTHER instance of Python in Activity Monitor, one that never seems to go above 1%
This happens even after a fresh restart of the whole computer.
Perhaps unrelated, but it also seems that various IndigoPluginServer processes, particularly EPS Device Extension and Hue Lights, are taking more processing time than they used to.
Open files for the greedy Python:
/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/INDIGOplotD.indigoPlugin/Contents/Server Plugin
/System/Library/Frameworks/Python.framework/Versions/2.7/Resources/Python.app/Contents/MacOS/Python
/System/Library/Frameworks/Python.framework/Versions/2.7/Python
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_locale.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/time.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/datetime.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_struct.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_json.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/binascii.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/strop.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_collections.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/operator.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/itertools.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_heapq.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/grp.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_functools.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/zlib.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_io.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/math.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/cPickle.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/cStringIO.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/core/_dotblas.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/lib/_compiled_base.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/future_builtins.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/core/multiarray.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/core/umath.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/core/scalarmath.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/linalg/lapack_lite.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/linalg/_umath_linalg.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/fft/fftpack_lite.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/random/mtrand.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_ctypes.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/select.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/fcntl.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_hashlib.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_random.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/_path.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_csv.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_socket.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_ssl.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_scproxy.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/ft2font.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/unicodedata.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/_png.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/_cntr.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/_image.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/_delaunay.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/_tri.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/backends/_backend_agg.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/special/_ufuncs.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/special/_ufuncs_cxx.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/special/specfun.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/interpolate/_fitpack.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/interpolate/dfitpack.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/linalg/_fblas.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/linalg/_flinalg.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/linalg/_flapack.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/linalg/calc_lwork.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/interpolate/interpnd.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/sparse/sparsetools/_csr.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/sparse/sparsetools/_csc.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/sparse/sparsetools/_coo.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/sparse/sparsetools/_dia.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/sparse/sparsetools/_bsr.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/sparse/sparsetools/_csgraph.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_bisect.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/sparse/csgraph/_shortest_path.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/sparse/csgraph/_tools.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/sparse/csgraph/_traversal.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/sparse/csgraph/_min_spanning_tree.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/spatial/ckdtree.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/spatial/qhull.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/scipy/spatial/_distance_wrap.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/resource.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/matplotlib/mpl-data/fonts/ttf/Vera.ttf
/usr/lib/dyld
/private/var/db/dyld/dyld_shared_cache_x86_64
/dev/null
/Users/macadmin/Documents/INDIGOplotD/matplot/matplot.log
/System/Library/CoreServices/SystemAppearance.bundle/Contents/Resources/SystemAppearance.car
/Library/Application Support/Perceptive Automation/Indigo 7/Logs/com.karlwachs.INDIGOplotD/plugin.log
->0x207ab4aae14f9f23
->0x207ab4aae14fa163
/dev/urandom
And for the non-greedy one:
/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/array.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC/objc/_objc.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/parser.so
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/pyexpat.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC/CoreFoundation/_inlines.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC/CoreFoundation/_CoreFoundation.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC/Foundation/_inlines.so
/usr/lib/libexpat.1.dylib
/usr/share/icu/icudt55l.dat
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC/Foundation/_Foundation.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC/WebKit/_WebKit.so
/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/Cheetah/_namemapper.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/OpenSSL/crypto.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/OpenSSL/rand.so
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/OpenSSL/SSL.so
/usr/lib/dyld
/dev/null
/dev/null
/dev/null
*:8176
unknown.domain:8176->old-ipad-i.domain:54444
localhost:49483->localhost:indigo-server
unknown.domain:8176->med-ed-ipad-3.domain:59612
/dev/urandom
->0x207ab4aae0e78993
count=2, state=0x12
Ideas? Is matplotlib really the culprit?
Fri Nov 25, 2016 4:23 pm
Re: Python x2 and using more CPU?
More info:
Unknown:~ macadmin$ which python
/usr/bin/python
Unknown:~ macadmin$ python -c "import sys; print sys.executable"
/usr/bin/python
Unknown:~ macadmin$ which -a python
/usr/bin/python
Unknown:~ macadmin$
Got this from looking at things like http://stackoverflow.com/questions/2584 ... v#25858171
Fri Nov 25, 2016 7:07 pm
Looks like some kind of issue with the INDIGOplotD plugin - I'd post over in his forums.
Fri Nov 25, 2016 7:11 pm
Possibly. Matplotlib doesn't do its own garbage collection, so it depends on how Karl has dealt with this.
Sat Nov 26, 2016 7:14 am
A) yes matplot is a resource hog. 90% of the cpu goes into one function in MATPLOT : plt.savefig() Thats where the actual PNG file gets created
There is a lot of discussion on this topic in MATPLOT forums
B) the memory usage goes up by ~ 100k per plot. Hence the plugin restarts the matplot part every ~ 100 loops to free up the memory at ~ 70Mbyte increased memory usage
This happens despite doing fig.clf() and plt.close(fig). after plt.savefig() to free up memory
I also tried garbage collection with gc.collect() , but that does not seem to help.
So yes it uses a lot of CPU and has memory leaks - that one is covered.
to compare: matplot uses ~ 1-10 seconds cpu (depending on your MAC and features) to create a plot with nice features , GNUPLOT uses less than 0.1 seconds for the same plots
Sat Nov 26, 2016 8:27 am
That seems to suggest GNUPLOT is an alternative, but I haven't seen anything about that here.
Sat Nov 26, 2016 9:09 am
indigoplotd can be used with MATPLOT and GNUPLOT.. BUT YOU NEED TO INSTALL GNUPLOT. I am using brew to install it.
see http://forums.indigodomo.com/viewtopic.php?f=165&t=15884 in the pdf on how to install it
as for CPU: my old 2008 mac pro ( 2 quad processors) runs easily with MATPLOT never > 30% load with security spy running ... while the 2014 mac mini (16GB i7 2 processors) goes to the limit
unfortunately next summer the OPSYS will run out of support on the Mac Pro
Sat Nov 26, 2016 10:25 am
Thanks! I'll give a shot at installing GNUPLOT and reconfiguring IndigoPlotD.
Seems I'm pushing an underpowered Mini with my setup. I'm running Indigo with multiple 3rd party plugins, NO-IP client, and my iTunes AirPlay server on a 2008 2.53 GHz Intel Core 2 Duo that's stock.
Sat Nov 26, 2016 12:53 pm
yes thats a little underpowered..
basic indigo and some simple plugins are ok, but anything with graphics and database activity will stretch it.
Tue Jul 04, 2017 8:21 am
hamw offline
I am on a 2010 mac mini, and am seeing a lot of CPU usage with indigoplotD, along with the python resource seen in activity monitor. Am using Marplot. is the so solution to change to gnu plot?
Tue Jul 04, 2017 8:40 am
matplot uses factor of 20 or more CPU than gnu plot. I spend a lot of time on this -- it is a known topic in the matplot discussion forums. The one call that actually does the plot consumes 95% . there is little one can do. Also matplot has a memory leak . but that is handled (restart it self every 100 iterations).
GNUPLOT does 99% of the things the same way. Some special things are different:
- left right line keys (gnu plot has one list, matplot put them left and right)
- line smoothing not as powerful (gnu plot only predefined methods)
