i7 Submit to Indigo Domotics bug
Sat Nov 12, 2016 8:28 pm
Selecting the button to Submit to Indigo Domotics results in a webpage appearing with just the following text:
Submit a Device
We appreciate your feedback. Please fill out the form below as completely as possible. Fields in bold are required. If you don’t fill out the form then we can't add it to our supported device list.
And a submit button but no fields to fill out. Clicking submit results in an error:
Unknown Error
which is hidden behind the Indigo Domotics logo at the top left of the page. No other information was visible.
This is the URL that the page is from:
http://www.indigodomo.com/devices/devic ... s=-+none+-
and here’s the indigo log from writing from the device:
Z-Wave Indigo Device "Hall - Front Door Lock" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.30
Node ID: 99
Model: Keypad Door Lock
Model ID: 00060000
Manufacturer: Yale
Manufacturer ID: 0129
Protocol Version: 3.34
Application Version: 22.32
Model Definition Version: 0
Library Type: 3
Class Name: Keypad Door Lock
Class Hierarchy: 04 : 40 : 03
Command Class Base: 62
Command Versions: 80v1 85v1 86v1 8Av1 8Bv1 4Cv1 4Ev1 98v1 20v1 62v1 63v1 70v1 71v1 72v1 75v1
Encryption Status: Enabled for Commands 80 62 63 85 86 8A 8B 4C 4E 70 71 72 75 98
Features: routing, battery, beaming, security, frequentWaking
Neighbors: 1, 3, 4, 5, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 35, 36, 81, 82, 84, 85, 88, 89, 91, 92, 95, 97
Associations: 1:[1]
Config Values: - none -
Sat Nov 12, 2016 8:40 pm
Re: i7 Submit to Indigo Domotics bug
Yeah, I'm looking at that now.
Sat Nov 12, 2016 8:51 pm
Try it again.
Sat Nov 12, 2016 8:57 pm
Seems to be working fine now, Danke!
