I do not find the device
Sun Nov 22, 2015 2:15 pm
StefID93 offline
Hello,
first of all I apologize for my bad English, but I'm Italian and I use the translator, I do not follow much the forum but like much indigo because of all controllers (I own them all for experiments) I think is the most stable, coming to the point, I went through your mind to reactivate my Veralite to put him in a house far from my main and currently empty, so to create a mini-theft I wanted to entrust this small controller, I sit at the computer and associate the fibaro door sensor He sees them well with UI7 latest version.
I open my mac and configure Vera Bridge with ip leaving unchanged the door, I create a new device nothing but the list it remains empty, so I think I make several attempts to return lla UI5 but nothing more and the empty list as I do?
P.S:the Veralite is still in my house so I'm doing everything from local
Mon Nov 23, 2015 10:38 am
Re: I do not find the device
Is your Vera on the same network as your Indigo Server? If not, are you sure that there are no firewalls in between that would be blocking communication?
Mon Nov 23, 2015 12:33 pm
StefID93 offline
Are under the same network and I disabled firewalls but always the same problem :(
I do not know what can bother him I did not do it firewall modem or strange configurations
Tue Nov 24, 2015 10:50 am
Turn on debugging in the Vera Bridge config and then reload the plugin. Then copy/paste the contents of the Event Log into a reply.
Tue Nov 24, 2015 2:26 pm
StefID93 offline
thanks for the help, I enabled debugging, I state that I left still UI5, although by the event log I see the changes when I try the door sensor will send the code
24/nov/2015 21:22:28
  Vera Bridge                     Turning on debug logging
  Vera Bridge Debug               vera thread: _update: starting at 21:22:29
  Vera Bridge Debug               vera thread: _update: url: http://192.168.1.3:3480//data_request?id=lu_sdata&output_format=json&loadtime=1448396355&dataversion=396355319
  Vera Bridge Debug               vera thread: _update: ending at 21:22:29
  Vera Bridge Debug               vera thread: _update: starting at 21:22:32
  Vera Bridge Debug               vera thread: _update: ending at 21:22:32
  Vera Bridge Debug               vera thread: _update: starting at 21:22:35
  Vera Bridge Debug               vera thread: _update: partial deviceInfo:
{u'comment': u'', u'room': u'1', u'parent': u'1', u'altid': u'2', u'lasttrip': u'1448396554', u'state': u'-1', u'batterylevel': u'92', u'armed': u'0', u'id': u'3', u'tripped': u'0', u'subcategory': u'3'}
  Vera Bridge Debug               vera thread: _update: ending at 21:22:35
  Vera Bridge Debug               runConcurrentThread: processing update: {'device': {u'comment': u'', u'room': u'1', u'parent': u'1', u'altid': u'2', u'lasttrip': u'1448396554', u'state': u'-1', u'batterylevel': u'92', u'armed': u'0', u'id': u'3', u'tripped': u'0', u'subcategory': u'3'}, 'updateType': 'updateDevice'}
  Vera Bridge Debug               processUpdate called
  Vera Bridge Debug               vera thread: _update: starting at 21:22:38
  Vera Bridge Debug               vera thread: _update: url: http://192.168.1.3:3480//data_request?id=lu_sdata&output_format=json&loadtime=1448396355&dataversion=396355322
{u'comment': u'', u'room': u'1', u'parent': u'1', u'altid': u'2', u'lasttrip': u'1448396556', u'state': u'-1', u'batterylevel': u'92', u'armed': u'0', u'id': u'3', u'tripped': u'1', u'subcategory': u'3'}
  Vera Bridge Debug               vera thread: _update: ending at 21:22:38
  Vera Bridge Debug               runConcurrentThread: processing update: {'device': {u'comment': u'', u'room': u'1', u'parent': u'1', u'altid': u'2', u'lasttrip': u'1448396556', u'state': u'-1', u'batterylevel': u'92', u'armed': u'0', u'id': u'3', u'tripped': u'1', u'subcategory': u'3'}, 'updateType': 'updateDevice'}
  Vera Bridge Debug               vera thread: _update: starting at 21:22:41
  Vera Bridge Debug               vera thread: _update: url: http://192.168.1.3:3480//data_request?id=lu_sdata&output_format=json&loadtime=1448396355&dataversion=396355324
{u'comment': u'', u'room': u'1', u'parent': u'1', u'altid': u'2', u'lasttrip': u'1448396561', u'state': u'-1', u'batterylevel': u'92', u'armed': u'0', u'id': u'3', u'tripped': u'0', u'subcategory': u'3'}
  Vera Bridge Debug               vera thread: _update: ending at 21:22:41
  Vera Bridge Debug               runConcurrentThread: processing update: {'device': {u'comment': u'', u'room': u'1', u'parent': u'1', u'altid': u'2', u'lasttrip': u'1448396561', u'state': u'-1', u'batterylevel': u'92', u'armed': u'0', u'id': u'3', u'tripped': u'0', u'subcategory': u'3'}, 'updateType': 'updateDevice'}
  Vera Bridge Debug               vera thread: _update: starting at 21:22:44
  Vera Bridge Debug               vera thread: _update: url: http://192.168.1.3:3480//data_request?id=lu_sdata&output_format=json&loadtime=1448396355&dataversion=396355326
{u'comment': u'', u'room': u'1', u'parent': u'1', u'altid': u'2', u'lasttrip': u'1448396563', u'state': u'-1', u'batterylevel': u'92', u'armed': u'0', u'id': u'3', u'tripped': u'1', u'subcategory': u'3'}
  Vera Bridge Debug               vera thread: _update: ending at 21:22:44
  Vera Bridge Debug               runConcurrentThread: processing update: {'device': {u'comment': u'', u'room': u'1', u'parent': u'1', u'altid': u'2', u'lasttrip': u'1448396563', u'state': u'-1', u'batterylevel': u'92', u'armed': u'0', u'id': u'3', u'tripped': u'1', u'subcategory': u'3'}, 'updateType': 'updateDevice'}
  Vera Bridge Debug               vera thread: _update: starting at 21:22:47
  Vera Bridge Debug               vera thread: _update: url: http://192.168.1.3:3480//data_request?id=lu_sdata&output_format=json&loadtime=1448396355&dataversion=396355328
  Vera Bridge Debug               vera thread: _update: ending at 21:22:47
  Vera Bridge Debug               _getNodeList called
  Vera Bridge Debug               vera thread: _update: starting at 21:22:50
  Vera Bridge Debug               vera thread: _update: ending at 21:22:50
  Vera Bridge Debug               vera thread: _update: starting at 21:22:53
  Vera Bridge Debug               vera thread: _update: ending at 21:22:53
  Vera Bridge Debug               vera thread: _update: starting at 21:22:56
  Vera Bridge Debug               vera thread: _update: ending at 21:22:56
  Vera Bridge Debug               vera thread: _update: starting at 21:22:59
  Vera Bridge Debug               vera thread: _update: ending at 21:22:59
  Vera Bridge Debug               vera thread: _update: starting at 21:23:02
  Vera Bridge Debug               vera thread: _update: ending at 21:23:02
  Vera Bridge Debug               closedDeviceFactoryUi
  Vera Bridge Debug               vera thread: _update: starting at 21:23:05
  Vera Bridge Debug               vera thread: _update: ending at 21:23:05
  Vera Bridge Debug               vera thread: _update: starting at 21:23:08
  Vera Bridge Debug               vera thread: _update: ending at 21:23:08
  Vera Bridge Debug               vera thread: _update: starting at 21:23:11
  Vera Bridge Debug               vera thread: _update: ending at 21:23:11
  Vera Bridge Debug               vera thread: _update: starting at 21:23:14
  Vera Bridge Debug               vera thread: _update: ending at 21:23:14
I just hope that you have configured something wrong I: D
Wed Nov 25, 2015 11:34 am
The Vera is only reporting one device - and it looks like a sensor device of some kind. The Vera Bridge plugin only supports a subset of device types and sensors are not one of them.
Wed Nov 25, 2015 12:37 pm
StefID93 offline
ah sorry I read now, perfect, so I have to create a script or make sure that when the device changes state to send the signal to indigo, will find a way
