Weird Vera Plugin Problem
Posted: Sat Sep 12, 2015 2:16 pm
So I have a Vera Lite and one lock connected to it. While I had defined "scenes" from the Vera Bridge web page, I was advised that I didn't need to do that, and that Indigo would be able to lock or unlock the door. This is still the case up until recently.
The lock is defined as a device, and from the Device Page, I can lock and unlock this device perfectly. It even reports back to Indigo it's status... my "security page" shows the proper state as I lock and unlock, either thru Indigo or manually. Yea!
But now, for some reason, the lock won't operate in an Action Group. I've got a long string of Leave/Arrive stuff and everything is working fine, except for the single Unlock or Lock command
I've created a new Action Group with just the Vera unlock command... but every time I fire the Action Group Manually, this shows up in the Event log
Vera Bridge Error vera thread: send command error: scene 17 does not exist or is inactive
I've rebooted the computer running Indigo, and I've re-booted the Vera Bridge. The only thing I haven't done is to delete the device and then add it back in..
Since Indigo is able to control the lock, I'm at a loss to figure out to get it to work...
