prism reflector troubles
Thu Jan 10, 2013 10:10 am
canoad56 offline
I changed computers because my laptop died and now I have a mac mini and am having trouble with goprism reflector. I downloaded the "prism fixer" but it did not work. below is the text copied from that program as you suggest:
-- Indigo Folder/File Permission Fixer --
Home User: alexdiaz
ID User: root
Folder: /Library/Application Support/Perceptive Automation/Indigo 5
Repairing Indigo folder owner and permissions:
Original: drwxrwxr-x / alexdiaz : admin
New: drwxrwxr-x / alexdiaz : admin
Complete.
Thu Jan 10, 2013 10:33 am
Re: prism reflector troubles
The log isn't showing that the fixer app found the prism preferences folder, so try to find this folder from the original Mac and copy it over to the new Mac (and run the fixer app again):
/Library/Application Support/Perceptive Automation/Indigo 5/Preferences/PrismReflector
And note the "Indigo 5" folder in the path will vary based on whatever version you were running on that Mac.
Thu Jan 17, 2013 11:35 am
canoad56 offline
Matt,
Thanks a bunch, worked like a gem !!
