Can not activate prism reflector
Tue Jan 01, 2013 12:07 pm
loodias offline
Help! I cannot get the prism reflector started. I just keep getting the weird, "Failed to activate your Reflector..." error message.
Here's my event log. Thanks to anyone who can help.
Jan 1, 2013 9:52:40 AM
Starting Indigo Server version 6.0.0 b3
Loading attachments
Loading interface "INSTEON Commands 2.0.1"
Starting interface "INSTEON Commands 2.0.1" (pid 854)
Found disabled interface "Z-Wave 1.0.15"
Found disabled plugin "Action Collection 1.3.0"
Found disabled plugin "Airfoil 1.0.5"
Found disabled plugin "Device Collection 1.0.1"
Found disabled plugin "DIRECTV DVR Control 1.0.0"
Found disabled plugin "EasyDAQ Relay Card 1.0.12"
Found disabled plugin "Growl 1.0.5"
Found disabled plugin "iCal Alarm Processor 1.0.3"
Found disabled plugin "iTunes 1.0.15"
Found disabled plugin "NOAA Weather 1.0.1"
Found disabled plugin "SQL Logger 1.1.5"
Found disabled plugin "Timers and Pesters 1.0.0"
Found disabled plugin "WeatherSnoop 1.1.1"
Bonjour registered "Indigo - 2008 N. Williams"
Error failed to create reflector connection: reflector not active
Indigo Cocoa client connected
Started interface "INSTEON Commands 2.0.1"
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Jan 1, 2013 9:52:45 AM
Connected to SmartHome PowerLinc USB E
PowerLinc address 0A.A2.64, firmware version 2.13
PowerLinc standalone operation disabled
Indigo directly controlling automation logic
Tue Jan 01, 2013 4:52 pm
Re: Can not activate prism reflector
Prism Reflector is currently not accepting new users or new reflectors. Existing reflectors that have already been activated will continue to work, but we are having to upgrade the server hardware and software before we can re-enable new reflector/account creation again. We don't have an ETA yet as to when it will be available, but we are actively working on it.
Wed Jan 02, 2013 1:08 pm
tmc3sticks offline
Matt,
I have just purchased a new computer and installed Indigo 5. My old computer was running the same software. How do I get the new computer to connect to the prism reflector (which was working on the old computer)?
Thanks in advance for the help.
Wed Jan 02, 2013 8:09 pm
loodias offline
Matt,
I had a prism reflector set-up before. Could it be i didn't input the right password or login?
Wed Jan 02, 2013 8:56 pm
The reflector key files are in this folder:
/Library/Application Support/Perceptive Automation/Indigo XYZ/Preferences/PrismReflector
(the XYZ suffix will depend on which version of Indigo you were running that was configured with a reflector)
So shutdown the Indigo Server (Indigo->Stop Server menu item), then copy that entire folder over into the Indigo 6 version of that path. If that doesn't work, then the files may not have the correct owner/permissions. You can use this permission healer app we made to fix those problems if they occur.
Wed Jan 02, 2013 9:24 pm
loodias offline
sorry...I should've told you that i tried that already.
Problem is I migrated to a new computer and lost that info I guess. Unfortunately, I don't have the old computer.
Wed Jan 02, 2013 9:29 pm
The private key file only exists on the Mac, so there is no way we can recover it. We are actively working on getting GoPrism.com functional on the new server though, so once that is up and running you can create a new reflector and it will work.
Wed Jan 02, 2013 10:17 pm
loodias offline
OK Thanks
Sat Jan 26, 2013 5:08 pm
The GoPrism.com service is now fully back online and accepting new accounts.
