Reflector Starts then shuts back down
Sun May 07, 2023 10:11 am
bobbyc176 offline
My reflector seems to be shutting itself off consistently after about a minute.
When I re-start the server it comes back but only for less than a minute.
It seems to have occurred once I upgraded to Indigo 2022.2.2
My server is a late 2014 Mac Mini running Monterrey 12.6.2
Thanks in advance!
Rob
Sun May 07, 2023 12:35 pm
Re: Reflector Starts then shuts back down
Hi Rob,
On your Indigo Server Mac try to access the following URL from Safari:
http://localhost:8176/prismstatus
what happens? Also open the Event Log window and copy/paste its contents into a reply for us.
Tue May 09, 2023 4:50 am
bobbyc176 offline
I get a "Safari Can't Connect to The Server" Error
Safari can't open the page "localhost:8176/prismstatus" because Safari can't connect to the server "localhost".
Log entries don't seem to show anything significant (to me anyway!)
May 9, 2023 at 6:42:58 AM
Alexa Warning Your reflector isn't available - you won't be able to use Alexa until the reflector is operating correctly.
May 9, 2023 at 6:43:28 AM
May 9, 2023 at 6:43:58 AM
May 9, 2023 at 6:44:28 AM
May 9, 2023 at 6:44:58 AM
Schedule Phones - Force Up Hourly
Z-Wave sent "Z-Wave 091 - Phone ATA Bridge" on
May 9, 2023 at 6:45:28 AM
May 9, 2023 at 6:45:58 AM
May 9, 2023 at 6:46:28 AM
Alexa Warn
Tue May 09, 2023 9:12 am
Have you upgraded your Mac to a new operating system or moved Indigo to a new Mac?
Restart your Indigo Server, let it run for a minute or two, then paste in any errors you see.
Tue May 09, 2023 5:14 pm
bobbyc176 offline
Hi Jay.... only change in the environment was upgrading to Indigo 2022.2.2
Here's the startup log.....
Rob
M
May 9, 2023 at 7:11:06 PM
Starting Indigo Server version 2022.2.2 on macOS Version 12.6.2 (Build 21G320)
Loading database "/Library/Application Support/Perceptive Automation/Indigo 2022.2/Databases/1431_20230318.indiDb"
Waiting for client to connect
Retrieved unchanged location for sunset/sunrise calculation
Indigo Cocoa client connected
Waiting for client to sync
Finding disabled plugins
Found disabled plugin "Sonos 1.0.17" using API v2.0
Warning plugin "Sonos 1.0.17" may not be compatible with next Indigo release without an update
Found disabled plugin "Zone-Scene Handler 1.0.375" using API v2.0
Warning plugin "Zone-Scene Handler 1.0.375" may not be compatible with next Indigo release without an update
Found disabled plugin "Global Property Manager 2022.1.0" using API v3.0
Found disabled plugin "Smartphone Radar 1.1.3" using API v1.0.0
Warning plugin "Smartphone Radar 1.1.3" may not be compatible with next Indigo release without an update
Found disabled plugin "Airfoil Pro 2022.1.0" using API v3.0
Found disabled interface "INSTEON Commands 2022.2.1" using API v3.0
Found disabled plugin "SQL Logger 2022.2.1" using API v3.0
Found disabled plugin "EasyDAQ Relay Card 2021.2.1" using API v3.0
Loading internal plugins
Loading interface "Z-Wave 2022.2.1" using API v3.0
Starting interface "Z-Wave 2022.2.1" (pid 86245)
Loading interface "Virtual Devices 2022.1.0" using API v3.0
Starting interface "Virtual Devices 2022.1.0" (pid 86246)
Loading plugin "Web Server 2022.2.0" using API v3.0
Starting plugin "Web Server 2022.2.0" (pid 86247)
Loading plugin "Action Collection 2022.2.0" using API v3.0
Starting plugin "Action Collection 2022.2.0" (pid 86248)
Loading plugin "Timers and Pesters 2022.1.0" using API v3.0
Starting plugin "Timers and Pesters 2022.1.0" (pid 86249)
Loading plugin "Email+ 2022.2.0" using API v3.0
Starting plugin "Email+ 2022.2.0" (pid 86250)
Loading plugin "Alexa 2022.2.0" using API v3.2
Starting plugin "Alexa 2022.2.0" (pid 86251)
Loading plugin "NOAA Weather 2022.2.6" using API v3.2
Starting plugin "NOAA Weather 2022.2.6" (pid 86252)
Loading plugin "Alexa-Hue Bridge 3.0.35" using API v2.0
Starting plugin "Alexa-Hue Bridge 3.0.35" (pid 86253)
Started plugin "Timers and Pesters 2022.1.0"
Started interface "Virtual Devices 2022.1.0"
Started plugin "Action Collection 2022.2.0"
Started plugin "Alexa 2022.2.0"
Alexa Finding devices to publish to Alexa...
Alexa ... 'Blinds Controller' published as 'The Blinds'
Alexa ... 'Dining Room' published as 'Dining Room'
Alexa ... 'Dining Room Sideboard' published as 'Dining Room Sideboard'
Alexa ... 'Dining Room Vase' published as 'Dining Room Vase'
Alexa ... 'Front Door Lights' published as 'Front Door'
Alexa ... 'Hall Bathroom Fan' published as 'Kevins Bathroom Fan'
Alexa ... 'Hall Bathroom Lights' published as 'Hall Bathroom Lights'
Alexa ... 'Hall Bathroom Shower Light' published as 'Hall Bathroom Shower Light'
Alexa ... 'Hallway Lights' published as 'Hallway'
Alexa ... 'Kevin's Bedside Light' published as 'Kevins Bedside Light'
Alexa ... 'Kitchen Counter Lights' published as 'Kitchen Counter'
Alexa ... 'Kitchen Florescent' published as 'Kitchen Laundry'
Alexa ... 'Kitchen Laundry' published as 'Kitchen Florescent'
Alexa ... 'Living Room' published as 'Living Room Lights'
Alexa ... 'Living Room 1' published as 'Living Room 1'
Alexa ... 'Living Room 2' published as 'Living Room 2'
Alexa ... 'Master Bathroom Fan' published as 'Master Bath Fan'
Alexa ... 'Master Bathroom Lights' published as 'Master Bath Lights'
Alexa ... 'Master Bathroom Shower Light' published as 'Master Bath Shower Light'
Started plugin "Email+ 2022.2.0"
Alexa ... 'Master Bedroom Ceiling Fan' published as 'Master Bedroom Ceiling Fan'
Alexa ... 'Master Bedroom Ceiling Fan Light' published as 'Master Bedroom Ceiling Fan Light'
Alexa ... 'Master Bedroom Light' published as 'Bedroom Light'
Alexa ... 'Robs Bedside Light' published as 'Robs Bedside Light'
Alexa ... 'Spare Room Closet Lights' published as 'Spare Room Closet Lights'
Alexa ... 'Z-Wave 020 - Composite' published as 'Bar Lights'
Alexa ... 'Z-Wave 104 - Thermostat' published as 'Temperature'
Alexa ... 'Z-Wave 997 - Blinds' published as 'Shades'
Alexa ... 'Z-Wave 997 - Blinds copy' published as 'Shades'
Alexa A total of 28 devices are currently published to Alexa
Alexa Warning If you can't control a device, run discover from your Alexa device or from the Alexa app.
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Alexa-Hue Bridge Plugin Host IP Address overridden and specified as: '192.168.1.90'
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge Warning Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, non-Echo Network Filter, Method Trace
Started plugin "Alexa-Hue Bridge 3.0.35"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge 'Alexa02' has 3 Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'Alexa02' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Alexa02' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'Alexa02' started: Host: 192.168.1.90 Port: 8178
Started plugin "NOAA Weather 2022.2.6"
Started interface "Z-Wave 2022.2.1"
NOAA Weather 'Weather Alerts - KIAD ' changed at 2023-05-02 20:00:00'.
Z-Wave connected to Z-Stick 7 (ZWA010) interface on /dev/cu.usbserial-14110 (firmware 7.00, minimum SDK 7.00.00)
NOAA Weather 'Weather Forecast - KIAD' changed at 2023-05-09 16:29:50'.
Started plugin "Web Server 2022.2.0"
Z-Wave found module included in controller with no matching device (missing or disabled): 031 - Portable Remote Controller
Z-Wave Error module 061 included in controller does not match device "Hall Bathroom Fan" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwRelayType (1, 1, 1))
Web Server starting internal Web server on http://localhost:8176
Z-Wave Error module 063 included in controller does not match device "Z-Wave 063 - Motion Sensor (HSM200)" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwOnOffSensorType (4, 16, 1))
Z-Wave Error module 067 included in controller does not match device "Z-Wave 085 - Master Bedroom Box Outlets" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwCustomType (4, 161, 2))
Z-Wave Error module 075 included in controller does not match device "Master Bathroom Fan" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwRelayType (2, 2, 7))
Z-Wave Error module 078 included in controller does not match device "Kitchen Lights" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwDimmerType (4, 32, 1))
Z-Wave Error controller reported unexpected or missing module information for some devices -- will reinitialize communication in 10 minutes
Waiting for internal plugins to initialize
Bonjour registered "Indigo - 1431_20230318"
Reflector starting reflector connection to https://bobbyc176-1431-2.indigodomo.net
Loading external plugins
Loading plugin "Occupatum 2022.1.5" using API v3.0
Starting plugin "Occupatum 2022.1.5" (pid 86261)
Loading plugin "Onkyo Network Remote Plugin 2.1.5" using API v2.1.0
Warning plugin "Onkyo Network Remote Plugin 2.1.5" may not be compatible with next Indigo release without an update
Starting plugin "Onkyo Network Remote Plugin 2.1.5" (pid 86262)
Loading plugin "Z-Wave Watcher 3.0.9" using API v3.0
Starting plugin "Z-Wave Watcher 3.0.9" (pid 86263)
Loading plugin "Multitool 2022.1.9" using API v3.0
Starting plugin "Multitool 2022.1.9" (pid 86264)
Loading plugin "Harmony Hub 2022.0.1" using API v3.0
Starting plugin "Harmony Hub 2022.0.1" (pid 86265)
Loading plugin "Z-Wave Lock Manager 3.0.66" using API v3.0
Starting plugin "Z-Wave Lock Manager 3.0.66" (pid 86266)
Loading plugin "Fibaro Light Manager 0.1.15" using API v1.19.0
Warning plugin "Fibaro Light Manager 0.1.15" may not be compatible with next Indigo release without an update
Starting plugin "Fibaro Light Manager 0.1.15" (pid 86267)
Loading plugin "TiVo Network Remote 2.2.1" using API v2.0
Warning plugin "TiVo Network Remote 2.2.1" may not be compatible with next Indigo release without an update
Starting plugin "TiVo Network Remote 2.2.1" (pid 86268)
Loading plugin "Z-Wave Node Matrix 2022.0.4" using API v3.0
Starting plugin "Z-Wave Node Matrix 2022.0.4" (pid 86269)
Loading plugin "EPS - Device Extensions 2.0.4" using API v2.0
Warning plugin "EPS - Device Extensions 2.0.4" may not be compatible with next Indigo release without an update
Starting plugin "EPS - Device Extensions 2.0.4" (pid 86270)
Loading plugin "Default Dimmer Level 0.1.0" using API v3.0
Starting plugin "Default Dimmer Level 0.1.0" (pid 86271)
Loading plugin "Samsung TV 1.0" using API v1.9
Warning plugin "Samsung TV 1.0" may not be compatible with next Indigo release without an update
Starting plugin "Samsung TV 1.0" (pid 86272)
Loading plugin "Ring 1.7.6" using API v2.0
Warning plugin "Ring 1.7.6" may not be compatible with next Indigo release without an update
Starting plugin "Ring 1.7.6" (pid 86273)
Loading plugin "iMessage Plugin 0.6.2" using API v3.0.0
Starting plugin "iMessage Plugin 0.6.2" (pid 86274)
Loading plugin "WeatherSnoop 3.2.0" using API v3.0
Starting plugin "WeatherSnoop 3.2.0" (pid 86275)
Loading plugin "utilities 2022.20.40" using API v3.0.0
Starting plugin "utilities 2022.20.40" (pid 86276)
Alexa-Hue Bridge Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
Alexa-Hue Bridge Alexa-Hue Bridge network access check to www.google.com successfully completed.
Started plugin "Occupatum 2022.1.5"
Occupatum Starting Occupatum
Started plugin "Default Dimmer Level 0.1.0"
Started plugin "Z-Wave Watcher 3.0.9"
Z-Wave Watcher Debug startup called
Z-Wave Watcher Debug Plugin version: 3.0.9
Started plugin "Multitool 2022.1.9"
Started plugin "Z-Wave Lock Manager 3.0.66"
Started plugin "Fibaro Light Manager 0.1.15"
Started plugin "Samsung TV 1.0"
Started plugin "Harmony Hub 2022.0.1"
Harmony Hub Harmony Hub starting
Started plugin "Onkyo Network Remote Plugin 2.1.5"
Started plugin "TiVo Network Remote 2.2.1"
Trigger Variable Update - TiVO Connection State
EPS - Device Extensions Error Exception encountered with /Library/Application Support/Perceptive Automation/Indigo 2022.2/Plugins/NOAA Weather.indigoPlugin (this error is NOT critical)
EPS - Device Extensions Error Exception in plugcache.refresh line 555: 'NoneType' object has no attribute 'data'
CODE: pluginXML["devices"] = self._parseDevicesXML(plugin + "/Contents/Server Plugin/Devices.xml")
Started plugin "Ring 1.7.6"
Ring Attempting to connect to Ring.com API and login as bobbyc176@gmail.com
Ring Connection to Ring.com API successful
Started plugin "utilities 2022.20.40"
utilities using '/Library/Frameworks/Python.framework/Versions/Current/bin/python3' for utily programs
utilities no fname:/Library/Application Support/Perceptive Automation/Indigo 2022.2/Preferences/Plugins/com.karlwachs.utilities/PLUGINSusedForCPUlimts.json
utilities testing if variable enableTimeTracking_utilities is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
utilities myLogSet setting parameters -- logFileActive= standard; logFile= ; debugLevel= []; maxFileSize= 100000
utilities initialized
utilities Utilities plugin initialized, ==> select action from plugin menu
Started plugin "WeatherSnoop 3.2.0"
Started plugin "EPS - Device Extensions 2.0.4"
EPS - Device Extensions Warning Upgrading plugin from version 1.53 or earlier
iMessage Plugin
iMessage Plugin ================================================ Initializing New Plugin Session =================================================
iMessage Plugin Plugin name: iMessage Plugin
iMessage Plugin Plugin version: 0.6.2
iMessage Plugin Plugin ID: com.GlennNZ.indigoplugin.iMessage
iMessage Plugin Indigo version: 2022.2.2
iMessage Plugin Python version: 3.10.2 (v3.10.2:a58ebcc701, Jan 13 2022, 14:50:16) [Clang 13.0.0 (clang-1300.0.29.30)]
iMessage Plugin Python Directory: /Library/Frameworks/Python.framework/Versions/3.10
iMessage Plugin System Release: 21.6.0
iMessage Plugin System Release Short: 21
iMessage Plugin System Version: Darwin Kernel Version 21.6.0: Sun Nov 6 23:31:16 PST 2022; root:xnu-8020.240.14~1/RELEASE_X86_64
iMessage Plugin ==================================================================================================================================
Started plugin "iMessage Plugin 0.6.2"
iMessage Plugin Connection to iMsg Database Successful.
Started plugin "Z-Wave Node Matrix 2022.0.4"
Waiting for external plugins to initialize
Onkyo Network Remote Plugin Error Connection timed out for device 978328769
Onkyo Network Remote Plugin Error Connection timed out for device 1219173948
EPS - Device Extensions EPS - Device Extensions is loaded and ready to use
Starting triggers and schedules
May 9, 2023 at 7:11:29 PM
Trigger Alert for Online Controller - Email
Indigo Cocoa client authenticated (192.168.1.74)
May 9, 2023 at 7:12:47 PM
Error reflector connection test failed: local server unreachable
Warning reflector reconnection scheduled in 5 seconds
Z-Wave received "Spare Room Closet Motion Sensor" status update battery level 99%
May 9, 2023 at 7:13:13 PM
Error failed to create reflector connection: local server unreachable
Error check your Firewall and Network configurations and try restarting the server
Warning reflector reconnection scheduled in 15 minutes
Tue May 09, 2023 5:37 pm
Does this URL fail:
but this one works:
http://127.0.0.1:8176/prismstatus
If so, then the problem is your Mac has become misconfigured and "localhost" doesn't route back to itself as it should. Note the file /etc/hosts should have this in it:
127.0.0.1   localhost
Tue May 09, 2023 6:31 pm
Do you have multiple network interfaces enabled? Ethernet AND WiFi, for instance?
Tue May 09, 2023 8:30 pm
bobbyc176 offline
Thank you everyone!
Turns out I had both Wired & Wi-Fi interfaces activated *and* my hosts file was blank. *How* it got blanked out is a mystery!
I edited the hosts file to defaults and turned off the wireless interface.
The boat seems back to an even keel now.
Thanks again!
Rob
