"Override Web Server (HTTP) port number 8176" Do I need it?
Mon Jan 02, 2023 4:42 pm
Jim22 offline
Just set up the Reflector. Works great so far.
Right now I have the following Checked.
What exactly is it for, and do I need it checked?
Jim
Mon Jan 02, 2023 6:35 pm
Re: "Override Web Server (HTTP) port number 8176" Do I need
That just allows you to customize the TCP port on which Indigo's Web server listens for incoming connections. The default is 8176, but if someone had a conflict with that port or wanted to change it for any other reason they can.
