Indigo Touch Connection Problem
Wed Jul 27, 2022 4:19 pm
bmilesfl offline
Re: Indigo Touch Connection Problem
New issue under same title....
My situation:
Recently had a hard drive crash (an iMac) and had to change to a new Mac mini
With the help of Indigo support (thank you), I was able to transfer the Indigo application files from my Time Machine backup to my new Mac mini.
Installed (downloaded) latest Indigo application and all of my devices, triggers, schedules, etc. are now present in the application and appear to work (happy!)
I added Indigo to my accepted firewall applications (Indigo 2022.1)
But, I'm getting a "Reflector Connection Down" message on my iPhone and cannot connect remotely.
I tried restarting the Indigo Server a few times.
I changed the Indigo Port setting to 1176 per some information on this forum.
No events in the Event Log with word "reflector"
Rebooted several times to see if it would fix it (did not).
Re-downloaded the Indigo App and reinstalled to see if it would fix it (did not).
Don't see the message on this new Mac mini I used to get from my older hard drive on start-up asking permission to connect to the IndigoServer
Any suggested next steps to try?
Wed Jul 27, 2022 5:58 pm
Thu Jul 28, 2022 3:04 am
bmilesfl offline
I tried the reflector reset and reactivation twice. But, did not fix the issue.
I do see this in my event log:
Jul 28, 2022 at 4:52:14 AM
Reloading plugin "Web Server 2022.1.1" using API v2.5
Starting plugin "Web Server 2022.1.1" (pid 859)
Error plugin "Web Server 2022.1.1" (pid 859) failed to start -- restarting in 20 seconds
I looked in the list of plug-ins and don't see a "Web Server..." plug-in. I then turned off all three plug-ins I had enabled to see if one of those were the issue, but it did not resolve. I still get the error above in my event log. That same error repeats every 20 seconds.
I also tried this solution https://forums.indigodomo.com/viewtopic.php?f=75&t=26223&p=210981&hilit=Web+Server+2022.1.1#p210981 (from another post) and it did not resolve the reflector issue, but it did get rid of the error noted above. See next post.
Thu Jul 28, 2022 3:32 am
bmilesfl offline
Regarding the post immediately above, here is my event log:
Jul 28, 2022 at 5:29:53 AM
Starting Indigo Server version 2022.1.2 on macOS Version 12.5 (Build 21G72)
Loading database "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Databases/Nottingham - Miles.indiDb"
Waiting for client to connect
Retrieved new location (28.582020, -81.361641) for sunset/sunrise calculation
Indigo Cocoa client connected
Waiting for client to sync
Error XML Parse Error: not well-formed (invalid token)
Error On character 61 of line number 21.
Finding disabled plugins
Found disabled plugin "DIRECTV DVR Control 1.1.1" using API v1.19
Found disabled plugin "Growl 7.4.1" using API v2.0
Found disabled plugin "Tesla EV Control 1.0.17" using API v2.0
Warning plugin "Tesla EV Control 1.0.17" may not be compatible with next Indigo release without an update
Found disabled interface "Z-Wave 2022.2.1" using API v3.0
Found disabled plugin "Harmony Hub 7.3.0" using API v2.0
Warning plugin "Harmony Hub 7.3.0" may not be compatible with next Indigo release without an update
Found disabled plugin "Sonos 0.9.8" using API v1.19
Warning plugin "Sonos 0.9.8" may not be compatible with next Indigo release without an update
Found disabled interface "Virtual Devices 2022.1.0" using API v3.0
Found disabled plugin "Global Property Manager 2022.1.0" using API v3.0
Found disabled plugin "Vera Bridge 1.0.10" using API v1.19
Found disabled plugin "Timers and Pesters 2022.1.0" using API v3.0
Found disabled plugin "Alexa 2022.1.0" using API v3.0
Found disabled plugin "Google Voice SMS 1.1.0" using API v1.0.0
Warning plugin "Google Voice SMS 1.1.0" may not be compatible with next Indigo release without an update
Found disabled plugin "Airfoil Pro 2022.1.0" using API v3.0
Found disabled plugin "Acme Future Home C-Panel System 1.2.0" using API v1.11
Found disabled plugin "NOAA Weather 2022.1.0" using API v3.0
Found disabled plugin "SQL Logger 2022.1.0" using API v2.5
Found disabled plugin "EasyDAQ Relay Card 2021.2.1" using API v3.0
Found disabled plugin "Alexa-Hue Bridge 3.0.35" using API v2.0
Found disabled plugin "Airfoil 1.1.14" using API v1.19
Found disabled plugin "WeatherSnoop 3.0.0" using API v2.0
Warning plugin "WeatherSnoop 3.0.0" may not be compatible with next Indigo release without an update
Found disabled plugin "iTunes 2021.1.0" using API v2.5
Found disabled plugin "iCal Alarm Processor 7.4.1" using API v2.0
Loading internal plugins
Loading plugin "Web Server 2022.1.1" using API v2.5
Starting plugin "Web Server 2022.1.1" (pid 1350)
Loading interface "INSTEON Commands 2022.1.0" using API v3.0
Starting interface "INSTEON Commands 2022.1.0" (pid 1351)
Loading plugin "Action Collection 2022.1.0" using API v3.0
Starting plugin "Action Collection 2022.1.0" (pid 1352)
Loading plugin "Email+ 2022.1.1" using API v3.0
Starting plugin "Email+ 2022.1.1" (pid 1353)
Started interface "INSTEON Commands 2022.1.0"
Started plugin "Action Collection 2022.1.0"
Started plugin "Email+ 2022.1.1"
Started plugin "Web Server 2022.1.1"
Web Server Starting Indigo Web Server...
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Waiting for internal plugins to initialize
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Loading external plugins
Loading plugin "Hue Lights 2022.12.40" using API v3.0
Starting plugin "Hue Lights 2022.12.40" (pid 1354)
Client disconnected
Client disconnected
Hue Lights Starting plugin initialization.
Hue Lights initializing ...
Hue Lights path To files: =================
Hue Lights detailed logging /Library/Application Support/Perceptive Automation/Indigo 2022.1/Logs/com.nathansheldon.indigoplugin.HueLights/plugin.log
Hue Lights testing logging levels, for info only:
Hue Lights logger enabled for INFO ==> TEST ONLY
Hue Lights Warning logger enabled for WARNING ==> TEST ONLY
Hue Lights Error logger enabled for ERROR ==> TEST ONLY
Hue Lights Error logger enabled for CRITICAL ==> TEST ONLY
Started plugin "Hue Lights 2022.12.40"
Hue Lights debug areas:[]
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Waiting for external plugins to initialize
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Web Server client connected
Web Server started on port 1176 -- authentication enabled: oauth, digest
Web Server disconnecting from Indigo server
Web Server client disconnected
Web Server Error Error in plugin execution startup:
File "plugin.py", line 705, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/.Web Server.indigoPlugin/Contents/Server Plugin/cherrypy/process/wspbus.py", line 184, in start
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/.Web Server.indigoPlugin/Contents/Server Plugin/cherrypy/process/wspbus.py", line 147, in publish
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/.Web Server.indigoPlugin/Contents/Server Plugin/cherrypy/_cpserver.py", line 90, in start
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/.Web Server.indigoPlugin/Contents/Server Plugin/cherrypy/process/servers.py", line 53, in start
File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/.Web Server.indigoPlugin/Contents/Server Plugin/cherrypy/process/servers.py", line 251, in wait_for_free_port
IOError: Port 1176 not free on '0.0.0.0'
Hue Lights Error Failed to connect to the Hue bridge at 192.168.1.186 after 4 seconds. - Check that the bridge is connected and turned on.
Hue Lights Warning bridge#0 -ip:192.168.1.186, hostId:GoBmj-fV8nj3NzPfIiSiIjcerumXOhTahftqlNx1; data returned ><, errors:{'': 'Failed to connect to the Hue bridge at 192.168.1.186 after 4 seconds. - Check that the bridge is connected and turned on.Failed to connect to the Hue bridge at 192.168.1.186 after 4 seconds. - Check that the bridge is connected and turned on.'}
Hue Lights bridge lights groups scenes users resources rules schedules sensors hostIds / user names ------------------- ip Numbers ---- BridgeIds-------
Hue Lights Warning #0 ; ipNumber:192.168.1.186 --- not properly setup, no data received from bridge, try to re-pair
Hue Lights Warning pluginPrefs IP#s: {"0": "192.168.1.186"}, ..hostIDs: {"0": "GoBmj-fV8nj3NzPfIiSiIjcerumXOhTahftqlNx1"}
Hue Lights Warning self.ipNumbers: {'0': '192.168.1.186'} self.hostIds:{'0': 'GoBmj-fV8nj3NzPfIiSiIjcerumXOhTahftqlNx1'}, paired:{'0': False}
Hue Lights ... initialized
Starting triggers and schedules
Jul 28, 2022 at 5:30:07 AM
Connected to PowerLinc 2413U interface on port usbserial-AL02YDFS
PowerLinc address 44.84.7B, firmware version 9.14
Hue Lights Warning bridge#0 -ip:192.168.1.186, hostId:GoBmj-fV8nj3NzPfIiSiIjcerumXOhTahftqlNx1; data returned ><, errors:{}
Thu Jul 28, 2022 8:54 am
Shutdown the server, disable any firewalls you have, then restart the server.
Thu Jul 28, 2022 4:05 pm
bmilesfl offline
Thank you Jay for the reply.
I tried those steps and I still get the "reflector connection Down" message on my Indigo Touch (v 2.1.2) app.
I also tried deactivating and activating my reflector too and then tried. Same outcome (not connecting).
Here is my event log for the above session:
Jul 28, 2022 at 6:01:45 PM
Retrieved unchanged location for sunset/sunrise calculation
Starting plugin "Web Server 2022.1.1" (pid 2476)
Starting interface "INSTEON Commands 2022.1.0" (pid 2477)
Starting plugin "Action Collection 2022.1.0" (pid 2478)
Starting plugin "Email+ 2022.1.1" (pid 2479)
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Starting plugin "Hue Lights 2022.12.40" (pid 2480)
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Jul 28, 2022 at 6:01:59 PM
Fri Jul 29, 2022 10:04 am
That really looks like you are having some systemic network issues (the Hue bridge also having connection issues and the constant client disconnect messages seem to reinforce the idea since neither of those are related to the reflector). I thought it might be some kind of firewall issue, but if you don't have any enabled that wouldn't be it. What kind of physical network connection are you using (WiFi, ethernet, etc)? Do you have any unusual network configurations (host name overrides, etc)?
Fri Jul 29, 2022 11:26 am
bmilesfl offline
Jay:
I did have my internet connection running through an Apple Extreme Router located next to my desktop. So, to rule that out, I just ran the ethernet cable from the wall to my new Mac mini's ethernet plug. I rebooted my machine and then stopped and restarted the Indigo application server. Next, I tried the deactivate/reactivate the reflector too. All of the above, including during my prior posts my firewall settings are on OFF.
The previous Hue notices were because I had those devices active in my Indigo device list (and plug-in), but had not plugged back in and reestablished the Hue Hub. So, I just deactivated all of those Including the plug-in) and those messages no longer appear in my Event Log.
Below is my latest event log that is showing up upon a server stop and start. I don't know what all those "client disconnect" messages relate to. Are those Indigo Server related or Apple / Mac mini O/S messages?
I still do not see my home indigo server listed in my Indigo Touch app.
I've not made any changes to my Network settings within the Apple O/S. I just accepted what was in there to begin with (out of the box). Is there something there I should look at? Let me know if you need any screen shots of that.
Finally, here is how my system is behaving now. Again, this is after recovering files from a Time Machine backup, installing a new Mac mini and then downloading and activating the latest version of Indigo. Not sure if these would provide any clues too:
1. I can turn on and off any device on my system from the Indigo desktop application
2. Certain scheduled routines are working while others are not. For example, I've always had a lights on at sunset with an all lights out at midnight scheduled event. But, now only the sunset lights on event happens and the lights off at midnight does not work.
3. My motion triggers have worked sporadically. Sometimes they will trigger the lights they are supposed to and somethings they do not. I resynched them all too and it did not resolve the intermittent issue.
Thanks again for hanging in there with me. And, for the help.
Jul 29, 2022 at 1:08:22 PM
Found disabled plugin "Tesla EV Control 3.0.2" using API v3.0
Found disabled plugin "Hue Lights 2022.12.40" using API v3.0
Starting plugin "Web Server 2022.1.1" (pid 900)
Starting interface "INSTEON Commands 2022.1.0" (pid 901)
Starting plugin "Action Collection 2022.1.0" (pid 902)
Starting plugin "Email+ 2022.1.1" (pid 903)
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Jul 29, 2022 at 1:08:29 PM
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Client disconnected
Jul 29, 2022 at 1:11:15 PM
Indigo Cocoa client disconnected
Fri Jul 29, 2022 3:33 pm
Take a screenshot of your Start Local Server dialog and email it to me (support@indigodomo.com). Reference this thread.
Fri Jul 29, 2022 5:35 pm
Never mind - you have both the Indigo (client) and the Web server configured with the same port numbers in the Start Local Server dialog. The can't be the same. The default is to have the web server port set to 8176 (not 1176).
Sat Jul 30, 2022 3:49 pm
bmilesfl offline
OMG! That was it. With that change, my home Indigo Server now shows up on my Indigo Touch app. Life is good once again!
Thank you so much. I appreciate you hanging in there with me.
