Cant get remote access to work
Mon Feb 28, 2022 2:56 pm
Sully offline
I recently moved from the west coast to the east coast and changed my ISP, I used to be able to connect indigo touch when away from my home,
now as soon as I leave my house I no longer can connect to the server. Do I need to change something for the new ISP?
Thanks in advance for any help
Tue Mar 01, 2022 2:45 pm
Re: Cant get remote access to work
What errors do you see in the Event Log when the server starts up?
Tue Mar 01, 2022 4:06 pm
Sully offline
See pic for only error
Screen Shot 2022-03-01 at 5.05.55 PM.png (13.67 KiB) Viewed 2046 times
Tue Mar 01, 2022 5:35 pm
That explains it :)
Reset your reflector's activation and that should fix it.
Wed Mar 02, 2022 8:46 am
Sully offline
I reset the reflector it now connects in the event list but still not able to control my system if I'm not on my homes wifi.
Thu Mar 03, 2022 2:17 pm
If it connects but controlling devices does nothing, then you likely still have Indigo running on a different Mac. Shutdown and uninstall Indigo on that Mac, then restart Indigo on your desired Mac and the reflector should connect to the correct server.
If it works but only when you aren't at home, then stop and restart the Indigo Server and copy/paste its Event Log window contents (actual text not a screen shot) into a reply.
Thu Mar 03, 2022 5:31 pm
Sully offline
Hmmmm, I sold my home in LA and sold the Indigo system with the house so there is definitely a new Mac mini running the system but the Mac mini I used for that house is in my new house. Would the name of the server for the reflector have anything to do with it? My systems were just called the home address, so my reflector account still says the old house address name. the new system server has a new name, when it starts it says connected to the old server name See below server name is *** pebble beach but reflector is *** elkwood
Starting Indigo Server version 2021.2.0 on macOS Version 10.15.3 (Build 19D76)
Loading database "/Library/Application Support/Perceptive Automation/Indigo 2021.2/Databases/PEBBLE BEACH DR.indiDb"
Waiting for client to connect
Indigo Cocoa client connected
Waiting for client to sync
Loading disabled plugins
Found disabled plugin "Growl 7.4.1"
Found disabled plugin "Tesla EV Control 1.0.19"
Found disabled interface "Virtual Devices 2021.1.0"
Found disabled plugin "Global Property Manager 2021.1.0"
Found disabled plugin "Timers and Pesters 2021.1.0"
Found disabled plugin "Alexa 2021.2.0"
Found disabled plugin "Airfoil Pro 2021.1.0"
Found disabled plugin "SQL Logger 2021.1.0"
Found disabled plugin "EasyDAQ Relay Card 2021.1.1"
Found disabled plugin "iTunes 2021.1.0"
Found disabled plugin "iCal Alarm Processor 7.4.1"
Loading internal plugins
Loading interface "Z-Wave 2021.2.0"
Starting interface "Z-Wave 2021.2.0" (pid 3352)
Loading plugin "Web Server 2021.2.0"
Starting plugin "Web Server 2021.2.0" (pid 3353)
Loading interface "INSTEON Commands 2021.1.0"
Starting interface "INSTEON Commands 2021.1.0" (pid 3354)
Loading plugin "Action Collection 2021.1.0"
Starting plugin "Action Collection 2021.1.0" (pid 3355)
Loading plugin "Email+ 2021.2.0"
Starting plugin "Email+ 2021.2.0" (pid 3356)
Loading plugin "NOAA Weather 2021.1.0"
Starting plugin "NOAA Weather 2021.1.0" (pid 3357)
Started interface "INSTEON Commands 2021.1.0"
Started plugin "NOAA Weather 2021.1.0"
Started plugin "Email+ 2021.2.0"
Started plugin "Action Collection 2021.1.0"
Started interface "Z-Wave 2021.2.0"
Started plugin "Web Server 2021.2.0"
Web Server Starting Indigo Web Server...
Web Server client connected
Web Server started on port 8176 -- authentication enabled: oauth, digest
Bonjour registered "Indigo - PEBBLE BEACH DR"
Reflector starting reflector connection to https://***
Waiting for internal plugins to initialize
Z-Wave connected to Z-Stick Gen5 (ZW090) interface on /dev/cu.usbmodem14301 (firmware 1.00, SDK unknown)
Z-Wave found module included in controller with no matching device (missing or disabled): 002 - Siren
Z-Wave found module included in controller with no matching device (missing or disabled): 003 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 004 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 005 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 006 - Multilevel Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 007 - Dimmable Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 008 - Dimmable Power Switch
Z-Wave received "KITCHEN BATH TEMPURATURE" sensor update to 74.2 °F
Z-Wave received "KITCHEN BATH HUMIDITY" sensor update to 23%
Z-Wave received "KITCHEN BATH LUMINANCE" sensor update to 0 lux
Z-Wave received "KITCHEN BATH UV" sensor update to 0
Loading external plugins
Starting triggers and schedules
Thu Mar 03, 2022 5:35 pm
Sully offline
If I click the reflector link and enter my password I can control my current house from a browser window, so the name of the reflector doesn't seem to matter
Fri Mar 04, 2022 5:49 pm
If this works, I think the problem is just your settings on your iPhone in Indigo Touch.
While at home on local WiFi from the Indigo Touch settings (gear icon) screen delete your current server then close and re-open the settings screen, and select your server (it should reappear). That will save into Indigo Touch your reflector name and then it should work when at home on WiFi or when away (via reflector).
Sat Mar 05, 2022 5:28 pm
Sully offline
That fixed it! Thanks.
