Reflector Work with T-Mobile Gateway?
Sat Feb 12, 2022 4:20 pm
ckeyes888 offline
Anyone know if the reflector will work using T-Mobile’s home internet gateway?
Carl
Sat Feb 12, 2022 7:14 pm
Re: Reflector Work with T-Mobile Gateway?
Don't see why it wouldn't. It does not need port forwarding or anything.
Sun Feb 13, 2022 3:09 pm
ckeyes888 offline
Thanks. Just not sure how any outside calls to anything on my local network could get thru
considering how T-Mobile uses a proprietary system designed for cell phones.
No public IP.
Also just found out the address of the gateway can’t be changed from it’s 192.168.12.49
Kinda blows all my devices using the more standard 192.168.1.xx.
Carl
Sun Feb 13, 2022 3:43 pm
No public IP.
Carl
The reflector connection is initiated from the Indigo server, which opens a two-way tunnel to the reflector server. So there's no inbound connection required.
I deliberately never use 192.168.1.X on any of my networks. It's too standard. Anyone trying to hack the router is going to try that network first. You're just fine using 192.168.12.X.
Sun Feb 13, 2022 4:39 pm
ckeyes888 offline
Great, thanks.
Carl
