Reflector errors
Fri Jul 10, 2020 10:00 pm
mintzps offline
Reflector errors
I have two systems running on Mac minis in two states (PA and DE) with two different ISPs and two different modem/router set-ups yet both are having reflector problems:
Here is log section from one:
2020-07-10 06:15:19 Error reflector connection test failed: unable to connect to server
2020-07-10 06:15:19 Error reflector reconnection scheduled in 5 seconds
2020-07-10 06:15:34 Reflector restarting reflector connection to https://mintzps.indigodomo.net
2020-07-10 06:56:53 Error reflector connection test failed: unable to connect to server
2020-07-10 06:56:53 Error reflector reconnection scheduled in 5 seconds
2020-07-10 06:57:05 Reflector restarting reflector connection to https://mintzps.indigodomo.net
2020-07-10 08:08:35 Error reflector connection test failed: unable to connect to server
2020-07-10 08:08:35 Error reflector reconnection scheduled in 5 seconds
2020-07-10 08:09:10 Error failed to create reflector connection: unable to connect to server
2020-07-10 08:09:10 Error reflector reconnection scheduled in 15 minutes
2020-07-10 08:24:40 Error failed to create reflector connection: unable to connect to server
2020-07-10 08:24:40 Error reflector reconnection scheduled in 15 minutes
2020-07-10 08:39:59 Reflector starting reflector connection to https://mintzps.indigodomo.net
2020-07-10 09:00:00 Schedule Allow Chime and Gable Fans
2020-07-10 09:11:00 Error reflector connection test failed: unable to connect to server
2020-07-10 09:11:00 Error reflector reconnection scheduled in 5 seconds
2020-07-10 09:11:35 Error failed to create reflector connection: unable to connect to server
2020-07-10 09:11:35 Error reflector reconnection scheduled in 15 minutes
2020-07-10 09:27:05 Error failed to create reflector connection: unable to connect to server
2020-07-10 09:27:05 Error reflector reconnection scheduled in 15 minutes
2020-07-10 09:40:53 Received INSTEON "Alarm" off
2020-07-10 09:40:53 Trigger Alarm disarmed
2020-07-10 09:40:53 Action Collection Alarm is now disarmed
2020-07-10 09:42:36 Error failed to create reflector connection: unable to connect to server
2020-07-10 09:42:36 Error reflector reconnection scheduled in 15 minutes
2020-07-10 09:58:06 Error failed to create reflector connection: unable to connect to server
2020-07-10 09:58:06 Error reflector reconnection scheduled in 15 minutes
2020-07-10 10:13:08 Reflector starting reflector connection to https://mintzps.indigodomo.net
2020-07-10 11:04:11 Error reflector connection test failed: unable to connect to server
2020-07-10 11:04:11 Error reflector reconnection scheduled in 5 seconds
2020-07-10 11:04:34 Reflector restarting reflector connection to https://mintzps.indigodomo.net
2020-07-10 11:39:28 Z-Wave received "Paul's garage input - on is open" status update is on
2020-07-10 11:41:06 Z-Wave received "Paul's garage input - on is open" status update is off
2020-07-10 12:15:44 Error reflector connection test failed: unable to connect to server
2020-07-10 12:15:44 Error reflector reconnection scheduled in 5 seconds
2020-07-10 12:15:58 Reflector restarting reflector connection to https://mintzps.indigodomo.net
Here is a log section from the other one:
2020-07-10 11:02:33 Error reflector connection test failed: unable to connect to server
2020-07-10 11:02:33 Error reflector reconnection scheduled in 5 seconds
2020-07-10 11:03:08 Error failed to create reflector connection: unable to connect to server
2020-07-10 11:03:08 Error reflector reconnection scheduled in 15 minutes
2020-07-10 11:18:09 Reflector starting reflector connection to https://mintzbeach.indigodomo.net
2020-07-10 11:28:30 Error reflector connection not open
2020-07-10 11:28:30 Error reflector reconnection scheduled in 5 seconds
2020-07-10 11:29:05 Error failed to create reflector connection: unable to connect to server
2020-07-10 11:29:05 Error reflector reconnection scheduled in 15 minutes
2020-07-10 11:44:35 Error failed to create reflector connection: unable to connect to server
2020-07-10 11:44:35 Error reflector reconnection scheduled in 15 minutes
2020-07-10 11:59:55 Reflector starting reflector connection to https://mintzbeach.indigodomo.net
2020-07-10 15:40:55 Error reflector connection test failed: unable to connect to server
2020-07-10 15:40:55 Error reflector reconnection scheduled in 5 seconds
2020-07-10 15:41:01 Reflector restarting reflector connection to https://mintzbeach.indigodomo.net
What is going on?
Sat Jul 11, 2020 2:11 am
GRWilde offline
Re: Reflector errors
I have also been getting frequent reflector connection problems recently. Here are the error logs for yesterday.
2020-07-10 01:02:27.788 Error reflector connection test failed: unable to connect to server
2020-07-10 01:02:27.789 Error reflector reconnection scheduled in 5 seconds
2020-07-10 01:33:27.655 Error reflector connection test failed: unable to connect to server
2020-07-10 01:33:27.656 Error reflector reconnection scheduled in 5 seconds
2020-07-10 03:15:01.222 Error reflector connection test failed: unable to connect to server
2020-07-10 03:15:01.222 Error reflector reconnection scheduled in 5 seconds
2020-07-10 03:15:36.496 Error failed to create reflector connection: unable to connect to server
2020-07-10 03:15:36.497 Error reflector reconnection scheduled in 15 minutes
2020-07-10 03:31:06.784 Error failed to create reflector connection: unable to connect to server
2020-07-10 03:31:06.784 Error reflector reconnection scheduled in 15 minutes
2020-07-10 03:49:10.174 Error resending previous command (reply mismatch)
2020-07-10 03:51:16.394 Error "Entry Hall Front Door Switch" on (scene 3 cleanup); send failed (no acknowledgment)
2020-07-10 04:57:51.286 Error reflector connection test failed: unable to connect to server
2020-07-10 04:57:51.286 Error reflector reconnection scheduled in 5 seconds
2020-07-10 05:08:47.700 Error reflector connection test failed: unable to connect to server
2020-07-10 05:08:47.700 Error reflector reconnection scheduled in 5 seconds
2020-07-10 05:20:15.930 Error reflector connection test failed: unable to connect to server
2020-07-10 05:20:15.930 Error reflector reconnection scheduled in 5 seconds
2020-07-10 05:20:51.193 Error failed to create reflector connection: unable to connect to server
2020-07-10 05:20:51.194 Error reflector reconnection scheduled in 15 minutes
2020-07-10 05:36:21.351 Error failed to create reflector connection: unable to connect to server
2020-07-10 05:36:21.351 Error reflector reconnection scheduled in 15 minutes
2020-07-10 05:51:51.897 Error failed to create reflector connection: unable to connect to server
2020-07-10 05:51:51.898 Error reflector reconnection scheduled in 15 minutes
2020-07-10 06:07:22.006 Error failed to create reflector connection: unable to connect to server
2020-07-10 06:07:22.007 Error reflector reconnection scheduled in 15 minutes
2020-07-10 08:00:09.260 Error "Master Bedroom LED Lights KeypadLinc" raw insteon command; send failed (no acknowledgment)
2020-07-10 08:03:41.935 Error reflector connection test failed: unable to connect to server
2020-07-10 08:03:41.935 Error reflector reconnection scheduled in 5 seconds
2020-07-10 08:04:17.211 Error failed to create reflector connection: unable to connect to server
2020-07-10 08:04:17.212 Error reflector reconnection scheduled in 15 minutes
2020-07-10 09:30:33.867 Error reflector connection test failed: unable to connect to server
2020-07-10 09:30:33.867 Error reflector reconnection scheduled in 5 seconds
2020-07-10 09:31:09.144 Error failed to create reflector connection: unable to connect to server
2020-07-10 09:31:09.145 Error reflector reconnection scheduled in 15 minutes
2020-07-10 10:27:08.821 Error reflector connection test failed: unable to connect to server
2020-07-10 10:27:08.821 Error reflector reconnection scheduled in 5 seconds
2020-07-10 10:51:01.894 Error resending previous command (reply mismatch)
2020-07-10 11:18:42.590 Error reflector connection test failed: unable to connect to server
2020-07-10 11:18:42.590 Error reflector reconnection scheduled in 5 seconds
2020-07-10 11:25:10.867 Error "Master Bedroom LED Lights KeypadLinc" on (scene 1 cleanup); send failed (no acknowledgment)
2020-07-10 11:31:47.130 Error resending previous command (reply mismatch)
2020-07-10 12:39:12.012 Error resending previous command (reply mismatch)
2020-07-10 12:54:40.126 Error device "WeatherSnoop" state key transmitterBatteryStatus not defined
2020-07-10 12:54:44.272 Error device "WeatherSnoop" state key transmitterBatteryStatus not defined
2020-07-10 12:54:44.273 Error device "WeatherSnoop" state key transmitterBatteryStatus not defined
2020-07-10 13:25:11.194 Error Unable to connect to IndigoDomo.com.
2020-07-10 15:00:25.234 Error resending previous command (reply mismatch)
2020-07-10 15:23:46.287 Error "Master Bedroom LED Lights KeypadLinc" off (scene 1 cleanup); send failed (no acknowledgment)
2020-07-10 17:28:20.586 Error resending previous command (reply mismatch)
2020-07-10 18:01:45.975 Error reflector connection test failed: unable to connect to server
2020-07-10 18:01:45.975 Error reflector reconnection scheduled in 5 seconds
2020-07-10 19:03:34.994 Error resending previous command (reply mismatch)
2020-07-10 19:03:36.561 Error resending previous command (busy or unexpected command)
2020-07-10 19:03:36.929 Error resending previous command (busy or unexpected command)
2020-07-10 19:20:50.718 Error resending previous command (reply mismatch)
2020-07-10 19:22:57.894 Error "Master Bedroom LED Lights KeypadLinc" off (scene 1 cleanup); send failed (no acknowledgment)
2020-07-10 19:45:02.172 Error "Master Bedroom LED Lights KeypadLinc" on (scene 1 cleanup); send failed (no acknowledgment)
2020-07-10 22:13:59.018 Error reflector connection test failed: unable to connect to server
2020-07-10 22:13:59.018 Error reflector reconnection scheduled in 5 seconds
2020-07-10 23:58:00.129 Schedule Email Event Log Errors
2020-07-10 23:58:00.130 Action Group Find All Event Log Errors
George Wilde
Sat Jul 11, 2020 8:55 am
Are you all still seeing problems? Our monitoring here isn't showing any issues; active good reflector connections have been very steady lately. Normally these issues end up being ISP routing issues causing connections to frequently break (which Indigo rebuilds). Normally the problems don't last long (since the ISP will eventually fix the underlying issue).
Sat Jul 11, 2020 3:55 pm
GRWilde offline
I am still getting connection errors frequently. Here are today's error logs til now:
2020-07-11 01:15:14.351 Error resending previous command (reply mismatch)
2020-07-11 03:39:24.744 Error resending previous command (reply mismatch)
2020-07-11 04:06:39.061 Error resending previous command (reply mismatch)
2020-07-11 04:06:39.509 Error "Upstairs Hall Stairway Switch" on to 30; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
2020-07-11 04:25:12.629 Error Unable to connect to IndigoDomo.com.
2020-07-11 06:26:51.661 Error reflector connection test failed: unable to connect to server
2020-07-11 06:26:51.661 Error reflector reconnection scheduled in 5 seconds
2020-07-11 06:35:50.879 Error resending previous command (reply mismatch)
2020-07-11 06:36:00.184 Error "EZIO Monitor" input binary states request; send failed (no acknowledgment)
2020-07-11 07:41:54.067 Better Email Error Indigo IMAP Server: Error connecting to IMAP server: [Errno 8] nodename nor servname provided, or not known
2020-07-11 07:41:54.069 Better Email Error Indigo IMAP Server: IMAP server connection error: [Errno 8] nodename nor servname provided, or not known
2020-07-11 08:00:19.316 Error "Master Bedroom Closet Light Switch" raw insteon command; send failed (no acknowledgment)
2020-07-11 08:39:10.152 Error resending previous command (reply mismatch)
2020-07-11 08:59:07.738 Error reflector connection test failed: unable to connect to server
2020-07-11 08:59:07.739 Error reflector reconnection scheduled in 5 seconds
2020-07-11 08:59:43.022 Error failed to create reflector connection: unable to connect to server
2020-07-11 08:59:43.022 Error reflector reconnection scheduled in 15 minutes
2020-07-11 09:15:13.342 Error failed to create reflector connection: unable to connect to server
2020-07-11 09:15:13.342 Error reflector reconnection scheduled in 15 minutes
2020-07-11 09:30:43.496 Error failed to create reflector connection: unable to connect to server
2020-07-11 09:30:43.496 Error reflector reconnection scheduled in 15 minutes
2020-07-11 10:01:00.603 HomeKit Bridge Error Exception in plugin.version_check line 256: HTTPSConnectionPool(host='api.indigodomo.com', port=443): Max retries exceeded with url: /api/v2/pluginstore/plugin-version-info.json?pluginId=com.eps.indigoplugin.homekit-bridge (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10fc83310>: Failed to establish a new connection: [Errno 8] nodename nor servname provided, or not known',))
2020-07-11 10:06:38.919 Error reflector connection test failed: unable to connect to server
2020-07-11 10:06:38.920 Error reflector reconnection scheduled in 5 seconds
2020-07-11 10:07:14.190 Error failed to create reflector connection: unable to connect to server
2020-07-11 10:07:14.191 Error reflector reconnection scheduled in 15 minutes
2020-07-11 10:43:07.302 Error reflector connection test failed: unable to connect to server
2020-07-11 10:43:07.302 Error reflector reconnection scheduled in 5 seconds
2020-07-11 10:44:12.262 Error reflector connection test failed: unable to connect to server
2020-07-11 10:44:12.262 Error reflector reconnection scheduled in 2 minutes
2020-07-11 10:47:32.916 Error reflector connection test failed: unable to connect to server
2020-07-11 10:47:32.917 Error reflector reconnection scheduled in 6 minutes
2020-07-11 10:54:27.794 Error reflector connection test failed: unable to connect to server
2020-07-11 10:54:27.795 Error reflector reconnection scheduled in 15 minutes
2020-07-11 11:10:18.739 Error reflector connection test failed: unable to connect to server
2020-07-11 11:10:18.740 Error reflector reconnection scheduled in 15 minutes
2020-07-11 11:25:49.006 Error failed to create reflector connection: unable to connect to server
2020-07-11 11:25:49.007 Error reflector reconnection scheduled in 15 minutes
2020-07-11 11:41:55.980 Error reflector connection test failed: unable to connect to server
2020-07-11 11:41:55.981 Error reflector reconnection scheduled in 15 minutes
2020-07-11 12:17:38.424 Error resending previous command (reply mismatch)
2020-07-11 12:35:24.010 Error "Entry Hall Stairway Switch (Load)" on (scene 3 cleanup); send failed (no acknowledgment)
2020-07-11 13:08:09.684 Error resending previous command (reply mismatch)
2020-07-11 13:28:08.139 Error reflector connection test failed: unable to connect to server
2020-07-11 13:28:08.139 Error reflector reconnection scheduled in 5 seconds
2020-07-11 13:59:18.061 Error reflector connection test failed: unable to connect to server
2020-07-11 13:59:18.061 Error reflector reconnection scheduled in 5 seconds
2020-07-11 13:59:53.368 Error failed to create reflector connection: unable to connect to server
2020-07-11 13:59:53.368 Error reflector reconnection scheduled in 15 minutes
2020-07-11 14:15:23.706 Error failed to create reflector connection: unable to connect to server
2020-07-11 14:15:23.706 Error reflector reconnection scheduled in 15 minutes
2020-07-11 14:50:22.765 Action Group Find All Event Log Errors
George Wilde
Sat Jul 11, 2020 4:26 pm
Your log is also showing network errors coming from several plugins, so it looks like a more general network issue and not reflector specific. I'd start by rebooting your Mac and network equipment (router, etc.).
Sat Jul 11, 2020 4:47 pm
mintzps offline
You didn't comment on my reflector errors. As I said I have 2 systems in 2 states running Indigo and I am having reflector errors on both. 2 different ISPs and modem router combos. And yes, I'm still seeing reflector errors today.
Sat Jul 11, 2020 5:39 pm
I checked both of your reflectors and they were up and connected when I checked. We'll look at the server logs some more, but it doesn't appear we are seeing connection drops (which is what you are having) at a higher rate than normal. The reflector tunnels are a persistent socket connection, which is susceptible to being broken/close by both your networking equipment, ISP, and routers all long the path to our hosted server. Indigo rebuilds the connection when it detects it has been broken, which is what your log is showing.
Are you continuing to see errors are both systems? Is it failing at the same rate as before?
Thu Jul 16, 2020 6:46 pm
mintzps offline
One system had one error the other had many.
Jul 16, 2020 at 3:10:38 AM
Starting Indigo Server version 7.4.0 (Mac OS X 10.14.6)
Loading database "/Library/Application Support/Perceptive Automation/Indigo 7.4/Databases/My House.indiDb"
Loading interface "Z-Wave 7.4.0"
Starting interface "Z-Wave 7.4.0" (pid 353)
Loading plugin "Online Sensor 0.0.14"
Starting plugin "Online Sensor 0.0.14" (pid 354)
Loading interface "INSTEON Commands 7.4.0"
Starting interface "INSTEON Commands 7.4.0" (pid 355)
Loading plugin "Action Collection 7.4.0"
Starting plugin "Action Collection 7.4.0" (pid 356)
Loading plugin "Better Email 7.2.9"
Starting plugin "Better Email 7.2.9" (pid 357)
Found disabled plugin "DIRECTV DVR Control 1.1.1"
Found disabled plugin "Growl 2.0.2"
Found disabled interface "Virtual Devices 2.0.5"
Found disabled plugin "Global Property Manager 2.0"
Found disabled plugin "Vera Bridge 1.0.10"
Found disabled plugin "Timers and Pesters 2.0.2"
Found disabled plugin "Airfoil Pro 1.0.9"
Found disabled plugin "NOAA Weather 2.0.1"
Found disabled plugin "SQL Logger 2.1.0"
Found disabled plugin "EasyDAQ Relay Card 2.0.3"
Found disabled plugin "Airfoil 1.1.14"
Found disabled plugin "iTunes 2.0.4"
Found disabled plugin "iCal Alarm Processor 2.0.1"
Bonjour registered "Indigo - My House"
Indigo Cocoa client connected
Started interface "INSTEON Commands 7.4.0"
Started plugin "Action Collection 7.4.0"
Started plugin "Better Email 7.2.9"
Better Email Starting Better Email
Started plugin "Online Sensor 0.0.14"
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Started interface "Z-Wave 7.4.0"
Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodem14601 (firmware 1.01)
Jul 16, 2020 at 3:10:43 AM
Trigger Insteon Restart
Better Email SMTP Server: Sending email 'Insteon Restart' to 'paul.s.mintz@gmail.com'
Connected to PowerLinc 2413U interface on port usbserial-A60332J4
PowerLinc address 3D.98.AF, firmware version 9.14
Jul 16, 2020 at 4:14:00 AM
Schedule Write WAN
Better Email SMTP Server: Sending email 'WAN Beachouse Address' to 'paul.s.mintz@gmail.com'
Jul 16, 2020 at 5:52:05 AM
Schedule Fish light off
Z-Wave sent "Fish Light" off
Jul 16, 2020 at 12:32:36 PM
Jul 16, 2020 at 7:00:00 PM
Schedule System on email
Email Sent to "paul.s.mintz@gmail.com"; subject "Insteon is running"
Jul 16, 2020 at 8:24:34 PM
Schedule Sconces on
Schedule Fish light on
Z-Wave sent "Garage Sconces" on
Z-Wave sent "Fish Light" on
Jul 16, 2020 at 8:33:19 PM
Schedule LR Lamp on
Z-Wave sent "Living Room Torchiere" on
Jul 16, 2020 at 8:35:26 PM
Indigo Cocoa client authenticated (73.130.245.217)
The other log
Jul 16, 2020 at 4:11:50 AM
Starting Indigo Server version 7.4.0 (Mac OS X 10.11.6)
Jul 16, 2020 at 4:13:08 AM
Starting plugin "Action Collection 7.4.0" (pid 416)
Starting interface "INSTEON Commands 7.4.0" (pid 417)
Starting interface "Z-Wave 7.4.0" (pid 418)
Loading plugin "AD2USB Alarm Interface 1.5.3"
Starting plugin "AD2USB Alarm Interface 1.5.3" (pid 419)
Loading plugin "Better Email 7.2.3"
Starting plugin "Better Email 7.2.3" (pid 420)
Loading plugin "Timers and Pesters 2.0.2"
Starting plugin "Timers and Pesters 2.0.2" (pid 421)
Loading interface "Virtual Devices 2.0.5"
Starting interface "Virtual Devices 2.0.5" (pid 422)
Found disabled plugin "Airfoil 1.1.11"
Found disabled plugin "apcupsd 0.4.2"
Found disabled plugin "DIRECTV DVR Control 1.1.0"
Found disabled plugin "Vera Bridge 1.0.8"
Started interface "Virtual Devices 2.0.5"
AD2USB Alarm Interface Log level preferences are set to "Normal".
Started plugin "Timers and Pesters 2.0.2"
Started plugin "Better Email 7.2.3"
Started plugin "AD2USB Alarm Interface 1.5.3"
AD2USB Alarm Interface Plugin setup completed. Ready to open link to the ad2usb in Advanced mode.
AD2USB Alarm Interface ad2usb opened for communication at socket://192.168.7.35:10000
Z-Wave connected to Z-Stick Plus (ZW090) interface on /dev/cu.usbmodem1471 (firmware 1.00)
Jul 16, 2020 at 4:13:28 AM
Trigger Restart
Connected to PowerLinc 2413U interface on port usbserial-AL02YDDJ
PowerLinc address 48.F0.31, firmware version 9.14
Email Sent to "paul.s.mintz@gmail.com"; subject "Indigo home restart"
Jul 16, 2020 at 4:30:00 AM
Schedule Turn On Front Lights AM
Z-Wave sent "Post Light" on
Z-Wave sent "Front stoop light" on
Trigger Turn on walk lights with stoop
Z-Wave sent "Walk lights" on
Z-Wave sent "Driveway Light" on
Jul 16, 2020 at 4:43:43 AM
Z-Wave received "012 - Freezer Door" status update battery level 100%
Jul 16, 2020 at 5:55:04 AM
Jul 16, 2020 at 5:55:39 AM
Jul 16, 2020 at 5:57:57 AM
Schedule Turn Off Front Lights AM
Z-Wave sent "Post Light" off
Z-Wave sent "Front stoop light" off
Trigger Turn off walk lights with stoop
Z-Wave sent "Walk lights" off
Z-Wave sent "Driveway Light" off
Sent INSTEON "Back Hall Light" off
Jul 16, 2020 at 6:10:40 AM
Jul 16, 2020 at 6:29:14 AM
Error XML Parse Error: not well-formed (invalid token)
Error On character 0 of line number 1.
Client authentication failed - bad XML received (193.27.228.239)
Client disconnected (193.27.228.239)
Error XML Parse Error: syntax error
Jul 16, 2020 at 8:02:01 AM
Jul 16, 2020 at 8:02:30 AM
Jul 16, 2020 at 9:00:00 AM
Jul 16, 2020 at 9:05:13 AM
WebServer Indigo Touch client connected from 73.130.245.217
Action Group Disarm alarm
Jul 16, 2020 at 9:43:38 AM
Jul 16, 2020 at 10:35:07 AM
Jul 16, 2020 at 10:35:42 AM
Jul 16, 2020 at 10:50:49 AM
Jul 16, 2020 at 11:20:02 AM
Z-Wave received "Solange's Garage Door - On is open" status update is on
Jul 16, 2020 at 11:24:38 AM
Z-Wave received "Solange's Garage Door - On is open" status update is off
Jul 16, 2020 at 1:53:13 PM
Jul 16, 2020 at 1:53:48 PM
Jul 16, 2020 at 2:08:51 PM
Jul 16, 2020 at 2:39:56 PM
Jul 16, 2020 at 2:40:32 PM
Jul 16, 2020 at 2:46:18 PM
Jul 16, 2020 at 2:47:29 PM
Jul 16, 2020 at 2:55:32 PM
Jul 16, 2020 at 3:46:35 PM
Jul 16, 2020 at 3:47:11 PM
Jul 16, 2020 at 4:02:12 PM
Jul 16, 2020 at 4:46:23 PM
Jul 16, 2020 at 4:53:35 PM
Jul 16, 2020 at 5:04:32 PM
Jul 16, 2020 at 5:04:57 PM
Jul 16, 2020 at 6:09:07 PM
Z-Wave received "Freezer Door" status update is on
Trigger Freezer timer starts
Z-Wave received "Freezer Door" status update is off
Trigger Freezer timer reset
Jul 16, 2020 at 6:16:22 PM
Jul 16, 2020 at 6:16:57 PM
Jul 16, 2020 at 6:32:27 PM
Jul 16, 2020 at 6:47:29 PM
Jul 16, 2020 at 6:49:28 PM
Jul 16, 2020 at 6:58:22 PM
Jul 16, 2020 at 6:58:57 PM
Jul 16, 2020 at 7:13:58 PM
Jul 16, 2020 at 8:04:56 PM
Jul 16, 2020 at 8:05:32 PM
Jul 16, 2020 at 8:21:02 PM
Jul 16, 2020 at 8:21:33 PM
Schedule Turn on Front Lights PM
Jul 16, 2020 at 8:31:33 PM
Trigger Sunset
Action Collection Sunset has occurred
Jul 16, 2020 at 8:31:55 PM
Fri Jul 17, 2020 4:14 pm
The one that had several drops also shows that the many of the attempts to recreate the connection fail when they are retried after 5 seconds, which results in Indigo trying again in 15 minutes. All of the attempts that are tried 15 minutes later succeed. It really looks like your ISP is having some issues (or your router / home network). Unfortunately, there isn't much Indigo can do in this case except continue to periodically retry the connection. I'd suggest you definitely restart your Mac and all networking equipment in the house to see if that helps.
You could also open the Terminal window and copy/paste in:
ping indigodomo.net
then just let it run indefinitely to see if there are periodic errors trying to reach our hosted server.
Sat Jul 18, 2020 2:42 pm
GRWilde offline
I am still getting frequent reflector errors. However I am able to access the reflector through my browser and receive current information, so this appears to be a periodic connection problem. I am having no problems that I am aware of with my ISP - Spectrum. Yesterday's error logs follow.
Incidentally, I am no longer having occasional crashes of my mac mini running Indigo and WeatherSnoop since I updated to Catalina 10.15.6 with its USB fixes.
Error Logs:
2020-07-17 01:23:37.727 Error XML Parse Error: not well-formed (invalid token)
2020-07-17 01:23:37.727 Error On character 0 of line number 1.
2020-07-17 01:23:39.733 Error XML Parse Error: not well-formed (invalid token)
2020-07-17 01:23:39.733 Error On character 0 of line number 1.
2020-07-17 01:23:39.733 Error XML Parse Error: syntax error
2020-07-17 01:23:39.734 Error XML Parse Error: not well-formed (invalid token)
2020-07-17 01:23:39.734 Error On character 0 of line number 1.
2020-07-17 02:18:32.840 Error reflector connection test failed: unable to connect to server
2020-07-17 02:18:32.840 Error reflector reconnection scheduled in 5 seconds
2020-07-17 04:50:27.948 Error reflector connection test failed: unable to connect to server
2020-07-17 04:50:27.949 Error reflector reconnection scheduled in 5 seconds
2020-07-17 04:51:03.218 Error failed to create reflector connection: unable to connect to server
2020-07-17 04:51:03.218 Error reflector reconnection scheduled in 15 minutes
2020-07-17 05:37:01.807 Error reflector connection test failed: unable to connect to server
2020-07-17 05:37:01.807 Error reflector reconnection scheduled in 5 seconds
2020-07-17 06:38:14.261 Error reflector connection test failed: unable to connect to server
2020-07-17 06:38:14.261 Error reflector reconnection scheduled in 5 seconds
2020-07-17 06:38:49.525 Error failed to create reflector connection: unable to connect to server
2020-07-17 06:38:49.526 Error reflector reconnection scheduled in 15 minutes
2020-07-17 06:50:41.210 Better Email Error Indigo IMAP Server: Error connecting to IMAP server: [Errno 8] nodename nor servname provided, or not known
2020-07-17 06:50:41.213 Better Email Error Indigo IMAP Server: IMAP server connection error: [Errno 8] nodename nor servname provided, or not known
2020-07-17 07:14:41.748 Error reflector connection test failed: unable to connect to server
2020-07-17 07:14:41.748 Error reflector reconnection scheduled in 5 seconds
2020-07-17 07:56:44.774 Error "Master Bedroom LED Lights KeypadLinc" on (scene 1 cleanup); send failed (no acknowledgment)
2020-07-17 09:05:31.140 Error Unable to connect to IndigoDomo.com.
2020-07-17 11:39:43.016 Error "Master Bedroom LED Lights KeypadLinc" off (scene 1 cleanup); send failed (no acknowledgment)
2020-07-17 12:07:45.050 Error reflector connection test failed: unable to connect to server
2020-07-17 12:07:45.050 Error reflector reconnection scheduled in 5 seconds
2020-07-17 12:18:41.234 Error reflector connection test failed: unable to connect to server
2020-07-17 12:18:41.235 Error reflector reconnection scheduled in 5 seconds
2020-07-17 12:19:16.498 Error failed to create reflector connection: unable to connect to server
2020-07-17 12:19:16.498 Error reflector reconnection scheduled in 15 minutes
2020-07-17 12:55:53.148 Error reflector connection test failed: unable to connect to server
2020-07-17 12:55:53.148 Error reflector reconnection scheduled in 5 seconds
2020-07-17 13:27:06.865 Error reflector connection test failed: unable to connect to server
2020-07-17 13:27:06.865 Error reflector reconnection scheduled in 5 seconds
2020-07-17 13:38:08.675 Error reflector connection test failed: unable to connect to server
2020-07-17 13:38:08.675 Error reflector reconnection scheduled in 5 seconds
2020-07-17 13:59:14.217 Error reflector connection test failed: unable to connect to server
2020-07-17 13:59:14.217 Error reflector reconnection scheduled in 5 seconds
2020-07-17 13:59:49.484 Error failed to create reflector connection: unable to connect to server
2020-07-17 13:59:49.484 Error reflector reconnection scheduled in 15 minutes
2020-07-17 14:01:09.285 Error device "WeatherSnoop" state key transmitterBatteryStatus not defined
2020-07-17 14:01:15.430 Error device "WeatherSnoop" state key transmitterBatteryStatus not defined
2020-07-17 14:01:15.431 Error device "WeatherSnoop" state key transmitterBatteryStatus not defined
2020-07-17 14:25:42.114 Error reflector connection test failed: unable to connect to server
2020-07-17 14:25:42.115 Error reflector reconnection scheduled in 5 seconds
2020-07-17 14:55:25.409 Error resending previous command (reply mismatch)
2020-07-17 15:06:44.584 Error reflector connection test failed: unable to connect to server
2020-07-17 15:06:44.584 Error reflector reconnection scheduled in 5 seconds
2020-07-17 15:37:42.108 Error reflector connection test failed: unable to connect to server
2020-07-17 15:37:42.108 Error reflector reconnection scheduled in 5 seconds
2020-07-17 15:59:00.490 Error reflector connection test failed: unable to connect to server
2020-07-17 15:59:00.490 Error reflector reconnection scheduled in 5 seconds
2020-07-17 17:10:59.815 Error reflector connection test failed: unable to connect to server
2020-07-17 17:10:59.815 Error reflector reconnection scheduled in 5 seconds
2020-07-17 17:21:59.825 Error reflector connection test failed: unable to connect to server
2020-07-17 17:21:59.826 Error reflector reconnection scheduled in 5 seconds
2020-07-17 17:22:35.087 Error failed to create reflector connection: unable to connect to server
2020-07-17 17:22:35.087 Error reflector reconnection scheduled in 15 minutes
2020-07-17 18:05:32.079 Error Unable to connect to IndigoDomo.com.
2020-07-17 18:08:28.928 Error reflector connection test failed: unable to connect to server
2020-07-17 18:08:28.928 Error reflector reconnection scheduled in 5 seconds
2020-07-17 18:50:01.107 Script Error embedded script: Python argument types in
2020-07-17 18:50:01.107 Script Error Exception Traceback (most recent call shown last):
ArgumentError: Python argument types in
2020-07-17 18:52:30.746 Error resending previous command (reply mismatch)
2020-07-17 20:00:32.505 Error "Master Bedroom LED Lights KeypadLinc" on (scene 1 cleanup); send failed (no acknowledgment)
2020-07-17 20:16:00.419 Error resending previous command (reply mismatch)
2020-07-17 20:16:02.002 Error resending previous command (busy or unexpected command)
2020-07-17 21:05:32.334 Error Unable to connect to IndigoDomo.com.
2020-07-17 22:00:01.040 Error "Master Bedroom LED Lights KeypadLinc" raw insteon command; failed
2020-07-17 22:00:11.625 Error "Master Bedroom Closet Light Switch" raw insteon command; failed (checksum invalid)
2020-07-17 22:54:27.346 Error resending previous command (timeout)
2020-07-17 22:54:33.721 Error "Upstairs Hall Stairway Switch" on to 100; send failed (no acknowledgment)
2020-07-17 23:58:00.564 Schedule Email Event Log Errors
2020-07-17 23:58:00.564 Action Group Find All Event Log Errors
George Wilde
Sat Jul 18, 2020 4:44 pm
Looks like a DNS error, maybe. Try changing from your ISP's DNS servers to OpenDNS or Google or some other public DNS servers.
Sat Jul 18, 2020 4:48 pm
Here's the settings for CloudFlare:
Screen Shot 2020-07-18 at 6.45.48 PM.jpg (97.38 KiB) Viewed 9411 times
Fri Mar 19, 2021 1:07 pm
gadgetnut offline
Hello, everyone. running Indigo 7.5 on a Mac Mini running macOS 11.2.3. The ISP is AT&T LTE.
We are getting recurrent error
Our Reflector URL seems to load reliably. Indigo Touch seems to work reliably. After a fresh restart of Mac Mini, the reflector error seems to go away for a short while.
In addition to the Reflector error we are also experiencing recurring errors with Python scripts that had been working perfectly for 3+ years. A salient part of the Python script error reads
embedded script: No status line
received - the server has closed the connection
It was suggested to me that the "server closed the connection" could also point to a general networking problem as opposed to a new problem with scripts that have been in place for years. FlyingDiver is kind enough to have contributed to that discussion in this thread.
After we restart the Mac Mini, both errors stop for a matter of minutes or hours. Right after restart we can manually execute the Python script and the intended action occurs (motorized shades move). But after a few minutes the script fails and we get the errors again.
Where should I direct my attention? What do you suspect is happening if network problems creep in after a restart? Problem at the router or software (reinstall macOS or Indigo?) or possible hardware problem at Mac Mini?
Thanks for any suggestions you can provide!
Fri Mar 19, 2021 1:09 pm
What kind of internet connection do you have?
Fri Mar 19, 2021 1:11 pm
gadgetnut offline
The ISP is AT&T LTE. We've been using LTE for more than a year without these errors. The most recent change I'm aware of is the macOS update.
