Reflector connection is currently down
Sat Jun 03, 2017 5:36 pm
samb offline
Hi
I've started receiving this message:
"reflector connection test failed: Reflector connection is currently down.
Error reflector reconnection scheduled in 5 seconds
Reflector restarting reflector connection to https://********.indigodomo.net"
It pops up like every 20 minutes. What can cause this?
/Sam
Sat Jun 03, 2017 7:40 pm
Re: Reflector connection is currently down
Have you tried restarting the Indigo server?
Sun Jun 04, 2017 2:05 am
samb offline
Yes, I've also reset and rebot my 4g router. Restarted the computer with no success.
Sun Jun 04, 2017 10:59 am
Yeah, it looks like your Indigo Server hasn't been able to connect to the reflector servers since 6/30 (at least that was the last time it successfully tunneled). Try Resetting your Reflector's Activation.
Sun Jun 04, 2017 11:08 am
Different Computers offline
Thanks to everyone who posted here. You enabled me to get my reflector running again after I had spent the last week thinking it was down because of my new DSL modem's configuration! (Yes, ANOTHER new one.)
Sun Jun 04, 2017 2:13 pm
samb offline
Ok, I've reset the reflector according to the instructions but it seems I have the same issue.
/Sam
Sun Jun 04, 2017 2:40 pm
On your Mac running the Indigo Server can you access:
https://demo.indigodomo.net/
from Safari?
Sun Jun 04, 2017 5:11 pm
samb offline
Yes.
Mon Jun 05, 2017 7:50 am
Send us an en email (support AT indigodomo DOT com) with a reference to this forum thread. We'll do some more detailed troubleshooting off the forum to see what is going wrong.
Mon Jun 05, 2017 8:50 am
It looks like your reflector is up - can you confirm?
Tue Jun 06, 2017 4:42 am
samb offline
It seems like it's going up and down all the time. I'll send the email!
/Sam
Sat Jul 22, 2017 5:21 pm
johnpolasek offline
Mine is now down, and from the log, it's been down since at least 3 pm. I have internet connection (using it now, in fact) and other services such as sitesage are running fine. Restarting the server didn't help... what's my next step?
Sat Jul 22, 2017 5:36 pm
Mines up at the moment.
Sat Jul 22, 2017 10:26 pm
Email us the contents of the Event Log window from the time you restarted the Indigo Server so we can see exactly what is occurring.
Sat Oct 06, 2018 8:42 am
arthurdaire offline
Dear
My reflector is also down. I have tried restarting the server and resetting the reflector with no luck.
Event long as below:
6 Oct 2018, 10:23:06 pm
Z-Wave received "Dining room - Luminance" sensor update to 0 lux
Reflector restarting reflector connection to https://daire75-home.indigodomo.net
Z-Wave received "Dining room - Temperature" sensor update to 20.8 °C
Z-Wave received "Dining room - Humidity" sensor update to 61%
Z-Wave received "Motion Sensor- Nana bedroom" status update is on
Z-Wave received "Motion Sensor - Ian" status update is on
Trigger Motion in Ian' s bedroom on
Sent Hue Lights "Ian bedroom hue" on to 25 at ramp rate 5.0 sec.
Error reflector connection test failed: Reflector connection is currently down.
Error reflector reconnection scheduled in 6 minutes
6 Oct 2018, 10:24:17 pm
Z-Wave received "Motion Sensor - Ian" status update is off
Trigger Motion in Ian' s bedroom off
Sent Hue Lights "Ian bedroom hue" on to 1 at ramp rate 5.0 sec.
Z-Wave received "Ian - Tamper" status update is off
6 Oct 2018, 10:24:41 pm
Z-Wave received "Nana - Luminance" sensor update to 14 lux
Trigger luminance front door variable change
Z-Wave received "nana - Temperature" sensor update to 20.6 °C
Trigger Bedroom _corridor_temp
Trigger Nana temp variable change
Z-Wave received "Nana - Humidity" sensor update to 68%
LIFX LIFX device discovery starting (this can take up to 60 seconds) . . .
LIFX
LIFX device discovery has completed and 5 LIFX device(s) have been successfully discovered.
The number of previously known LIFX devices awaiting discovery is 1.
LIFX Device 1: 'Cor 3' [d0:73:d5:00:4b:cf] discovered at address 192.168.1.10 on port 56700.
LIFX Device 2: 'Corr 2' [d0:73:d5:00:53:58] discovered at address 192.168.1.16 on port 56700.
LIFX Device 3: 'Study' [d0:73:d5:00:34:be] discovered at address 192.168.1.24 on port 56700.
LIFX Device 4: 'Living room' [d0:73:d5:01:65:f0] discovered at address 192.168.1.19 on port 56700.
LIFX Device 5: 'Cor 1' [d0:73:d5:01:66:36] discovered at address 192.168.1.21 on port 56700.
LIFX Device 6: 'Dining room' [d0:73:d5:00:78:95] is not yet visible on the network and therefore a further discovery is required.
As one or more LIFX devices are still awaiting discovery, another discovery has been scheduled for 5 minutes time.
Disable undiscovered device(s) if further discoveries are not required.
6 Oct 2018, 10:25:28 pm
Z-Wave received "Motion Sensor- Nana bedroom" status update is off
Trigger Motion in Annabelles bedroom off
Sent Hue Lights "Annabelle bedroom hue" on to 60 at ramp rate 5.0 sec.
6 Oct 2018, 10:25:52 pm
Trigger Motion in Annabelles bedroom on
Sent Hue Lights "Annabelle bedroom hue" on to 25 at ramp rate 5.0 sec.
Updated "Annabelle bedroom hue" on to 100
6 Oct 2018, 10:28:35 pm
Z-Wave received "009 - front door sensor " status update battery level 100%
Updated "Annabelle bedroom hue" on to 93
6 Oct 2018, 10:29:02 pm
Updated "Annabelle bedroom hue" on to 60
Z-Wave received "Motion sensor - Living room" status update is on
Trigger Motion in Living room on
Trigger Start variable timer
LIFX sent "LivingRoom" on with duration of 0.1 seconds
6 Oct 2018, 10:29:23 pm
6 Oct 2018, 10:29:52 pm
Error reflector reconnection scheduled in 15 minutes
LIFX
LIFX Device 2: 'Living room' [d0:73:d5:01:65:f0] discovered at address 192.168.1.19 on port 56700.
LIFX Device 3: 'Cor 1' [d0:73:d5:01:66:36] discovered at address 192.168.1.21 on port 56700.
LIFX Device 4: 'Study' [d0:73:d5:00:34:be] discovered at address 192.168.1.24 on port 56700.
LIFX Device 5: 'Corr 2' [d0:73:d5:00:53:58] discovered at address 192.168.1.16 on port 56700.
Z-Wave received "Living room motion - Tilt/Tamper" status update is off
Z-Wave received "Motion sensor - Living room" status update is off
6 Oct 2018, 10:35:02 pm
WUnderground Error Error downloading satellite image. Error: (Line 1098 [Errno 2] No such file or directory: u'/User/username/Desktop/satellite-imagery.png')
LIFX
6 Oct 2018, 10:36:41 pm
Z-Wave received "Nana - Luminance" sensor update to 15 lux
Z-Wave received "nana - Temperature" sensor update to 20.5 °C
6 Oct 2018, 10:38:46 pm
Z-Wave received "Ian - Temperature" sensor update to 23.0 °C
Trigger Temp-Ian variable change
Z-Wave received "Ian- Humidity" sensor update to 67%
Z-Wave received "Ian- Luminance" sensor update to 0 lux
Z-Wave received "Ian - Ultraviolet" sensor update to 0
Z-Wave received "035 - Motion Sensor - Ian" status update battery level 100%
6 Oct 2018, 10:39:09 pm
Z-Wave received "Living room motion - Luminance" sensor update to 5 lux
6 Oct 2018, 10:39:38 pm
Z-Wave received "Motion Sensor- Study" status update is on
6 Oct 2018, 10:40:08 pm
LIFX
LIFX Device 4: 'Corr 2' [d0:73:d5:00:53:58] discovered at address 192.168.1.16 on port 56700.
6 Oct 2018, 10:40:34 pm
Z-Wave received "019 - Motion Sensor- Nana bedroom" status update battery level 5%
6 Oct 2018, 10:41:36 pm
Z-Wave received "Main bedroom - Temperature" sensor update to 22.4 °C
Trigger Temp-Nana variable change
Z-Wave received "Main bed - Humidity" sensor update to 71%
Z-Wave received "Main bed - Luminance" sensor update to 17 lux
Trigger luminance NanaBR variable change
Z-Wave received "Main bed - Ultraviolet" sensor update to 0
Z-Wave received "034 - Motion Sensor - Main bedroom" status update battery level 100%
Thanks for the help
Arthur
